James R Posted November 28, 2020 Share Posted November 28, 2020 Hi all, got an install coming up - galaxy flex panel with dt pirs Any advice from anyone who has fitted these? Not my choice, it's been specced by others. Honeywell programming software looks like it costs an F-ing fortune. What's up with that? Regards Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted November 28, 2020 Share Posted November 28, 2020 22 minutes ago, James R said: Hi all, got an install coming up - galaxy flex panel with dt pirs Any advice from anyone who has fitted these? Not my choice, it's been specced by others. Honeywell programming software looks like it costs an F-ing fortune. What's up with that? Regards I personally quite like galaxy panels you can just program via keypad instead of using the software Quote Link to comment Share on other sites More sharing options...
James R Posted November 28, 2020 Author Share Posted November 28, 2020 1 minute ago, Imnotshankled said: I personally quite like galaxy panels you can just program via keypad instead of using the software I will be - got a quote, about 900 quid for their remote service suit with one licence - Key pad it is then... Quote Link to comment Share on other sites More sharing options...
norman Posted November 28, 2020 Share Posted November 28, 2020 How big is the system? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
James R Posted November 28, 2020 Author Share Posted November 28, 2020 1 hour ago, norman said: How big is the system? Panel - gprs comms module- ip comms module - 15 dt pirs... I'm thinking I'm gonna set it up and program in the office before I hand it to my installer. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 28, 2020 Share Posted November 28, 2020 2 hours ago, James R said: Panel - gprs comms module- ip comms module - 15 dt pirs... I'm thinking I'm gonna set it up and program in the office before I hand it to my installer. You blagging? Cos I professional blagger and only room for.ome here Quote Link to comment Share on other sites More sharing options...
norman Posted November 28, 2020 Share Posted November 28, 2020 2 hours ago, James R said: Panel - gprs comms module- ip comms module - 15 dt pirs... I'm thinking I'm gonna set it up and program in the office before I hand it to my installer. I installed classic galaxy for years and always used the keypad, never had an issue just used to carry one on a flylead and find somewhere comfortable to do it. Even better doing it on the bench in the comfort of your office. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
James R Posted November 28, 2020 Author Share Posted November 28, 2020 48 minutes ago, al-yeti said: You blagging? Cos I professional blagger and only room for.ome here Blagging how lad? Quote Link to comment Share on other sites More sharing options...
whistle Posted November 29, 2020 Share Posted November 29, 2020 Programmed a GD48 with 26 circuits this week from the keypad in 1/2 hour including various outputs and UDL Dualcom. Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted November 29, 2020 Share Posted November 29, 2020 9 hours ago, al-yeti said: You blagging? Cos I professional blagger and only room for.ome here Challenge accepted Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted November 30, 2020 Share Posted November 30, 2020 On 28/11/2020 at 20:59, James R said: Panel - gprs comms module- ip comms module - 15 dt pirs... I'm thinking I'm gonna set it up and program in the office before I hand it to my installer. If port forwarding for use with the GX app, you can only lock down the RSS and UMS passwords with RSS at the moment. In saying that, the best advice is to use a VPN rather than opening ports up. Quote Link to comment Share on other sites More sharing options...
James R Posted November 30, 2020 Author Share Posted November 30, 2020 18 hours ago, GalaxyGuy said: If port forwarding for use with the GX app, you can only lock down the RSS and UMS passwords with RSS at the moment. In saying that, the best advice is to use a VPN rather than opening ports up. Hi, dont have the RSS. Can't justify the cost as we don't do a lot of galaxy. One question, got an ip module that's been specced - would that just connect to customers network to be able to use the app? Regards Quote Link to comment Share on other sites More sharing options...
James R Posted November 30, 2020 Author Share Posted November 30, 2020 18 hours ago, GalaxyGuy said: If port forwarding for use with the GX app, you can only lock down the RSS and UMS passwords with RSS at the moment. In saying that, the best advice is to use a VPN rather than opening ports up. They also specced a gsm/gprs comms module - we are setting up radio/radio Dualcom for keyholder monitoring, I take it there's no need for the honeywell module as well? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted November 30, 2020 Share Posted November 30, 2020 3 hours ago, James R said: They also specced a gsm/gprs comms module - we are setting up radio/radio Dualcom for keyholder monitoring, I take it there's no need for the honeywell module as well? No, but it can be used for direct SMS. The Ethernet module can be used for the gx app, allowing remote control. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 30, 2020 Share Posted November 30, 2020 3 hours ago, James R said: They also specced a gsm/gprs comms module - we are setting up radio/radio Dualcom for keyholder monitoring, I take it there's no need for the honeywell module as well? If you can avoid the app do so , it's messy , the selfmon virtual keypad might do them if they want to set from bed lol Quote Link to comment Share on other sites More sharing options...
