Developer Posted November 21, 2020 Share Posted November 21, 2020 Hello guys, I have a faulty heat detector in a 5839 HMO system (a mix of about 12 heat/smoke/call points) I've take the head off and "silenced" the fault buzzer in the downstairs panel, that comes on when a head is removed. My question is - does the rest of the system remain active while the faulty head is off, until I can get a new one on Monday? Thanks. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 21, 2020 Share Posted November 21, 2020 1 hour ago, Developer said: Hello guys, I have a faulty heat detector in a 5839 HMO system (a mix of about 12 heat/smoke/call points) I've take the head off and "silenced" the fault buzzer in the downstairs panel, that comes on when a head is removed. My question is - does the rest of the system remain active while the faulty head is off, until I can get a new one on Monday? Thanks. Not my expertise But wouldn't it silence otherwise? System will be in fault , you can always active something to find out Quote Link to comment Share on other sites More sharing options...
james.wilson Posted November 21, 2020 Share Posted November 21, 2020 Depends on what you have, if it's installed correctly then yes but you have took on the liability by removing it. You should of called your maintainer Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
