mikejc Posted November 8, 2020 Share Posted November 8, 2020 Hi all, New to the alarm game. I've recently had extensive work done at my house and took the opportunity to put alarm cables at all windows and external doors and for a couple for PIRs. Purchased a used flex 50 from ebay. I've powered it up and seems to be showing the right signs of working properly (led on after 30 secs then flashing every 1.5 secs). I also have a mk8 prox keypad arriving soon. Is there anything I can do to check the keypad is functioning ok so I know if I need to return it? Also, any recommendations for PIRs (have no pet at the moment but might in the future)? Also need an external sounder (also have an alarm cable for this). Thanks Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 8, 2020 Share Posted November 8, 2020 if you have perimeter protection then you would be best programming the system around pets, pet sensors can have mixed results and with starting from design stage you are better not using them. i normally look for sealed optics generally fitting Optex but other brands like Bosch have sealed quads. Buying from ebay isn't ideal if you have no idea what your testing for, although if you have the panel wire it all up, program and bench test it first. Don't rate the light up external sounders but with the main manufacturers they are more chosen on aesthetics and branding for installers really. Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted November 8, 2020 Share Posted November 8, 2020 1 hour ago, mikejc said: Hi all, New to the alarm game. I've recently had extensive work done at my house and took the opportunity to put alarm cables at all windows and external doors and for a couple for PIRs. Purchased a used flex 50 from ebay. I've powered it up and seems to be showing the right signs of working properly (led on after 30 secs then flashing every 1.5 secs). I also have a mk8 prox keypad arriving soon. Is there anything I can do to check the keypad is functioning ok so I know if I need to return it? Also, any recommendations for PIRs (have no pet at the moment but might in the future)? Also need an external sounder (also have an alarm cable for this). Thanks Hopefully, you're not powering up without a keypad. If you do that, then you cannot use the correct process to power down (menu 51.17-power off) and wait until the keypad shows 'Safe to power off'. With Flex, if you just pull the power, you have a small chance that you will corrupt the flash filesystem, leaving the panel bricked. 2 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 1 hour ago, mikejc said: Hi all, New to the alarm game. I've recently had extensive work done at my house and took the opportunity to put alarm cables at all windows and external doors and for a couple for PIRs. Purchased a used flex 50 from ebay. I've powered it up and seems to be showing the right signs of working properly (led on after 30 secs then flashing every 1.5 secs). I also have a mk8 prox keypad arriving soon. Is there anything I can do to check the keypad is functioning ok so I know if I need to return it? Also, any recommendations for PIRs (have no pet at the moment but might in the future)? Also need an external sounder (also have an alarm cable for this). Thanks Wait for keypad and connect it to see if it works? Quote Link to comment Share on other sites More sharing options...
mikejc Posted November 8, 2020 Author Share Posted November 8, 2020 43 minutes ago, sixwheeledbeast said: if you have perimeter protection then you would be best programming the system around pets, pet sensors can have mixed results and with starting from design stage you are better not using them. i normally look for sealed optics generally fitting Optex but other brands like Bosch have sealed quads. Buying from ebay isn't ideal if you have no idea what your testing for, although if you have the panel wire it all up, program and bench test it first. Don't rate the light up external sounders but with the main manufacturers they are more chosen on aesthetics and branding for installers really. thanks. Yes all external entries have sensors. I had considered using PIRs for home automation but from what I've read on this forum that may not be easily achievable. As you say I'll just stick with the windows and door sensors for now. Quote Link to comment Share on other sites More sharing options...
mikejc Posted November 8, 2020 Author Share Posted November 8, 2020 36 minutes ago, GalaxyGuy said: Hopefully, you're not powering up without a keypad. If you do that, then you cannot use the correct process to power down (menu 51.17-power off) and wait until the keypad shows 'Safe to power off'. With Flex, if you just pull the power, you have a small chance that you will corrupt the flash filesystem, leaving the panel bricked. Ok thanks was not aware. Powered up once to see if it worked. I'll wait for the keypad to arrive before I do it again. 17 minutes ago, al-yeti said: Wait for keypad and connect it to see if it works? I will now. I guess there's nothing in particular to look out for then Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 8, 2020 Share Posted November 8, 2020 I am not saying to omit the PIR's completely just that I wouldn't consider pet ones. 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 9 minutes ago, mikejc said: Ok thanks was not aware. Powered up once to see if it worked. I'll wait for the keypad to arrive before I do it again. I will now. I guess there's nothing in particular to look out for then See what errors keypad show? Quote Link to comment Share on other sites More sharing options...
mikejc Posted November 8, 2020 Author Share Posted November 8, 2020 2 minutes ago, al-yeti said: See what errors keypad show? Will do. Bought it used and only get a few days to determine if faulty so hopefully no errors. Didn't pay much for it so was a risk worth taking Quote Link to comment Share on other sites More sharing options...
mikejc Posted November 8, 2020 Author Share Posted November 8, 2020 26 minutes ago, sixwheeledbeast said: I am not saying to omit the PIR's completely just that I wouldn't consider pet ones. Right I misunderstood you. Are the pet ones not reliable? Quote Link to comment Share on other sites More sharing options...
