Euro 46 psu battery fault
Yeah I've changed a tyre on a xj220 too.
However on the euro have you checked the fuse on the battery. It does look like a board issue though. Bear in mind the euro does sense battery volts and demand and adjusts charging accordingly
4 hours ago, Mark Rider said:
well i have a battery tester and have tested it like i said and its ok
 No wonder people dont use professionals as there all as arrogant as you.
as i said i have all the tools just wanted some advice as not fully up to speed on alarms
as i work on 800v Porsche Taycans
So then you know how to fix , as no point using professionals lol
Anyhow what he said above is correct , you call it arrogance but it's forum banter , arrogance is your reply
Follow through the detailed help from Mr H and think about what jw just said
Then go back to your Porsche vehicles , while I work on some Toyota hybrids all the same to me......
Edited by al-yeti
  • Upvote 1
act ?
Me? I told you who to mend your alarm for nowt
Battery, fuse or PCB
impressive.... however there'll be much cheaper & much less powerful than a big wagon
P8byQMBp-xojXvZSYK0wq9U-8jjS04R0UwZyHcyI
they appear to do electric ones if you lack diesel skills ?
  • Like 1
Mr? Veritas God
3 hours ago, Amps said:
How/where did you manage to download the Pyronix insite software!
They don't exactly make it hard to get dude , just like wintex etc
All aimed at DIY trying to show they trade lol
5 hours ago, Amps said:
So new battery fitted and still the same
Same faults
 Also with the power off you can't do a start with just the battery doesn't seem to do anything at all.
 So looks like it's the panel
So question the V10 is the layout much the same on the panel ?
Or battery which damaged the panel or something else that did it
IIRC needs mains to start,
Power it down
Remove the modem connection,
Rainbow ribbon if fitted
bell +
Speaker+
Zem +
Aux + on both tiers of the pcb terminals
Check all the pcb fuses with DVM on buzz (replace any blown one with correct value)
Restart with just the RKP on it, if won't change onto the battery its deffo shagged
think its the same pcb, but but minor sorfware changes which includes app support ?
Mr? Veritas God
Power it down
bell +
Speaker+
Zem +
Ok will do see what happens thanks ? I let you know
