Mark Rider Posted November 7, 2020 Share Posted November 7, 2020 Hello so have had a euro46 for last 3 years installed by my self all been fine then all of a sudden got faults fault is Battery fault , PSU fault , Low volts, battery critical so i measure volts on psu thats 20v AC and battery is 13.4 volts so there all good so not sure why its gone faulty screen shots of UDL software attached got no idea where to go now strange thing is the UDL software isnt showing the volts or current any help is good thanks very much Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 7, 2020 Share Posted November 7, 2020 1 minute ago, Mark Rider said: Hello so have had a euro46 for last 3 years installed by my self all been fine then all of a sudden got faults fault is Battery fault , PSU fault , Low volts, battery critical so i measure volts on psu thats 20v AC and battery is 13.4 volts so there all good so not sure why its gone faulty screen shots of UDL software attached got no idea where to go now strange thing is the UDL software isnt showing the volts or current any help is good thanks very much What makes you think just because volts ok battery is good , your forgetting something..... Average battery life is done Quote Link to comment Share on other sites More sharing options...
Mark Rider Posted November 7, 2020 Author Share Posted November 7, 2020 as i have checked the battery. drop test etc powers other stuff ok as well for got to add the control panel also says the psu power is below 10.38volts Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 7, 2020 Share Posted November 7, 2020 Just now, Mark Rider said: as i have checked the battery. drop test etc powers other stuff ok as well for got to add the control panel also says the psu power is below 10.38volts Cool your ok then , don't need a PSU don't need a battery Sorted As said 3 years is enough for battery in my.opinion , perhaps it's damaged your psu I doubt you have a battery drop tester for this type ? Quote Link to comment Share on other sites More sharing options...
Mark Rider Posted November 7, 2020 Author Share Posted November 7, 2020 ??? how can it be ok then if it has a fault because of low power ? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 7, 2020 Share Posted November 7, 2020 Just now, Mark Rider said: ??? how can it be ok then if it has a fault because of low power ? Was being sarcastic..... Just forum banter dude , your still ignoring the battery has been running for charging for three years and it's the first thing to swap out , but you say you measure good voltage from PSU but panel reports low voltage I would say your testing things wrong somehow but it's all hear say as we can't see what you do Change battery , failing that psu Quote Link to comment Share on other sites More sharing options...
Mark Rider Posted November 7, 2020 Author Share Posted November 7, 2020 ok lol well im a High Voltage vehicle tech so know how to measure current and voltage so thats not a problem. So do you know what voltage should be coming out the PSU ? also when you disconnect the battery the alarm sounds which it didnt do before but if you turn power off it shuts down with no battery back up . Quote Link to comment Share on other sites More sharing options...
MrHappy Posted November 7, 2020 Share Posted November 7, 2020 The "black act of alarm monkeying" Diagnosis with out tools- Unplug & shake the battery , does it rattle like a skeleton having a wank in a biscuit tin ? look at the current reading displayed on the keypad is probably gonna be 1000mA + ? remove one lead form battery is probably gonna be 450mA it may well be warm & sooty in the endstation pull the battery fuse on the pcb you'll probably get 100 Battery Fuse failed or similar on the display in day mode (proves the fuse is good) When you pull the mains & The system just dies Battery fuse Battery Or endstation pcb Pull a known good battery in & repeat Diagnosis with a multimeter- A battery has a float charge of less than 100mA an uncharged battery say 1000mA, measure the current you should be able to watch it fall to float charge, Transformer kicks out 20vac, The battery leads will either measure nowt or around 14vdc depending on product with no battery fitted Proper alarm co. will have a battery tester & current reading of the system in day & alarm Quote Mr Veritas God Link to comment Share on other sites More sharing options...
norman Posted November 7, 2020 Share Posted November 7, 2020 *art, but lol otherwise. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Mark Rider Posted November 7, 2020 Author Share Posted November 7, 2020 well i have a battery tester and have tested it like i said and its ok No wonder people dont use professionals as there all as arrogant as you. as i said i have all the tools just wanted some advice as not fully up to speed on alarms as i work on 800v Porsche Taycans Quote Link to comment Share on other sites More sharing options...
james.wilson Posted November 8, 2020 Share Posted November 8, 2020 Yeah I've changed a tyre on a xj220 too. However on the euro have you checked the fuse on the battery. It does look like a board issue though. Bear in mind the euro does sense battery volts and demand and adjusts charging accordingly Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 (edited) 4 hours ago, Mark Rider said: well i have a battery tester and have tested it like i said and its ok No wonder people dont use professionals as there all as arrogant as you. as i said i have all the tools just wanted some advice as not fully up to speed on alarms as i work on 800v Porsche Taycans So then you know how to fix , as no point using professionals lol Anyhow what he said above is correct , you call it arrogance but it's forum banter , arrogance is your reply Follow through the detailed help from Mr H and think about what jw just said Then go back to your Porsche vehicles , while I work on some Toyota hybrids all the same to me...... Edited November 8, 2020 by al-yeti 1 Quote Link to comment Share on other sites More sharing options...
Amps Posted November 8, 2020 Share Posted November 8, 2020 6 hours ago, Mark Rider said: as i said i have all the tools just wanted some advice as not fully up to speed on alarms How/where did you manage to download the Pyronix insite software! Quote Link to comment Share on other sites More sharing options...
MrHappy Posted November 8, 2020 Share Posted November 8, 2020 8 hours ago, Mark Rider said: well i have a battery tester and have tested it like i said and its ok act ? 8 hours ago, Mark Rider said: No wonder people dont use professionals as there all as arrogant as you. Me? I told you who to mend your alarm for nowt Battery, fuse or PCB 8 hours ago, Mark Rider said: 800v Porsche Taycans impressive.... however there'll be much cheaper & much less powerful than a big wagon they appear to do electric ones if you lack diesel skills 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Mark Rider Posted November 8, 2020 Author Share Posted November 8, 2020 3 hours ago, Amps said: How/where did you manage to download the Pyronix insite software! From there website . It's good bit of software. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 3 hours ago, Amps said: How/where did you manage to download the Pyronix insite software! They don't exactly make it hard to get dude , just like wintex etc All aimed at DIY trying to show they trade lol Quote Link to comment Share on other sites More sharing options...
Mark Rider Posted November 8, 2020 Author Share Posted November 8, 2020 5 hours ago, Amps said: So new battery fitted and still the same Same faults Also with the power off you can't do a start with just the battery doesn't seem to do anything at all. So looks like it's the panel So question the V10 is the layout much the same on the panel ? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 14 minutes ago, Mark Rider said: So looks like it's the panel So question the V10 is the layout much the same on the panel ? Or battery which damaged the panel or something else that did it Quote Link to comment Share on other sites More sharing options...
MrHappy Posted November 8, 2020 Share Posted November 8, 2020 1 hour ago, Mark Rider said: Also with the power off you can't do a start with just the battery doesn't seem to do anything at all. So looks like it's the panel IIRC needs mains to start, Power it down Remove the modem connection, Rainbow ribbon if fitted bell + Speaker+ Zem + Aux + on both tiers of the pcb terminals Check all the pcb fuses with DVM on buzz (replace any blown one with correct value) Restart with just the RKP on it, if won't change onto the battery its deffo shagged 1 hour ago, Mark Rider said: So question the V10 is the layout much the same on the panel ? think its the same pcb, but but minor sorfware changes which includes app support ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Mark Rider Posted November 8, 2020 Author Share Posted November 8, 2020 2 hours ago, MrHappy said: IIRC needs mains to start, Power it down Remove the modem connection, Rainbow ribbon if fitted bell + Speaker+ Zem + Aux + on both tiers of the pcb terminals Check all the pcb fuses with DVM on buzz (replace any blown one with correct value) Restart with just the RKP on it, if won't change onto the battery its deffo shagged think its the same pcb, but but minor sorfware changes which includes app support ? Ok will do see what happens thanks I let you know Quote Link to comment Share on other sites More sharing options...
Mark Rider Posted November 8, 2020 Author Share Posted November 8, 2020 No good won't start with it all disconect Quote Link to comment Share on other sites More sharing options...
Amps Posted November 8, 2020 Share Posted November 8, 2020 5 hours ago, al-yeti said: They don't exactly make it hard to get dude , just like wintex etc All aimed at DIY trying to show they trade lol Thought you had to be a registered installer? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 12 minutes ago, Amps said: Thought you had to be a registered installer? Anyone register with some companies just blag it Even with hikvision you can get away with it and blag it But you couldn't get hkc software without being registered the software itself keeps tabs on you , and they know when you download it and login Quote Link to comment Share on other sites More sharing options...
Amps Posted November 8, 2020 Share Posted November 8, 2020 4 minutes ago, al-yeti said: Anyone register with some companies just blag it Even with hikvision you can get away with it and blag it But you couldn't get hkc software without being registered the software itself keeps tabs on you , and they know when you download it and login Ok didn't realise it was that easy. You think the software always linked to a email address? Just wondering how companies stop rouge engineers logging in after they have left the company. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 8, 2020 Share Posted November 8, 2020 1 hour ago, Amps said: Ok didn't realise it was that easy. You think the software always linked to a email address? Just wondering how companies stop rouge engineers logging in after they have left the company. Don't know , but now are you not talking about logging into panel? As for software you can create more users and delete when they leave Not sure how others work but seems to work for hkc Quote Link to comment Share on other sites More sharing options...
