Bammers Posted October 8, 2020 Share Posted October 8, 2020 Hi, I have a old Galaxy 60 panel, V4.5 and want to install a Ethernet module. I know the new Ethernet mods don’t work on this model but some old ones do. I have been offered a V4.03 but not sure if this works. Any info would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted October 9, 2020 Share Posted October 9, 2020 22 hours ago, Bammers said: Hi, I have a old Galaxy 60 panel, V4.5 and want to install a Ethernet module. I know the new Ethernet mods don’t work on this model but some old ones do. I have been offered a V4.03 but not sure if this works. Any info would be greatly appreciated. Thanks The new Ethernet modules should work on the older hardware, as the bus protocol has not changed. V4.03 and V4.11 will work. You'll not get the maxpro CCTV platform capability, as the older panels do not support the isom protocol in their menu system. Quote Link to comment Share on other sites More sharing options...
Bammers Posted April 17, 2021 Author Share Posted April 17, 2021 On 09/10/2020 at 08:25, GalaxyGuy said: The new Ethernet modules should work on the older hardware, as the bus protocol has not changed. V4.03 and V4.11 will work. You'll not get the maxpro CCTV platform capability, as the older panels do not support the isom protocol in their menu system. Thank you. Quote Link to comment Share on other sites More sharing options...
