A1 alarms S.A.B module wiring help!
24 minutes ago, sterling t said:
IMG_3060.thumb.JPG.a7167dac345c73a9e4aa951e8595bf17.JPGIMG_3060.thumb.JPG.a7167dac345c73a9e4aa951e8595bf17.JPGi need help with connections. there is no label saying what terminal does what. i would be greatful if anyone can help
You know how to trace components? As ground and +12 should be easy to find
See which terminal is linked to the transistor then that should be your sounder output
Does the chip have 555 on it, as with a couple of caps that your timing circuit so your trigger would go to that chip
Edited by Nova-Security
www.nova-security.co.uk
www.nsiapproved.co.uk
28 minutes ago, PeterJames said:
Why ? Just bin it and by a new bell. surely its cheaper than spending hours fking around with an old bit of tat thats older than the contents of the property your protecting
well, it's not going to be protecting anything, i collect old bell boxes and this is going inside a vented bell box.
chinese ebay thing ?
I certainly can't recall surface components on  Bell Module I've ever seen...
louvered...
Mr? Veritas God
No fun then?
