Castle 2500 line fault.
PeteGBR
3 minutes ago, PeteGBR said:
What I posted is certainly not a riddle but looks clear as mud my problem. I need a manual.
Apologies. I thought it was totally unambiguous.
So do you have the engineer code and access the settings , this isn't a panel I know well
But now your saying you have removed the board and that's why the fault came up
Can you not put the board back and then just remove line reporting?
As as above then you can connect pins for signalling
13 minutes ago, PeterJames said:
Stop talking in riddles and just say what you want to do FFS
If you cant un program the LF just link it out its not rocket science
Lol
The truth is i'm whipped by the company i work for - So spending hours on site messing about with something that was installed in 2000 is not really healthy for me.
I thought I would research the panel before i went back to site like a professional. But I reallised that amongst the 100's of manuals I have accumulated over the last 30 years in this industry I don't have a Castle 2500 installation and wiring manual.
I Need to resolve it though.
Hmmm... I wonder if that Digi still works. Dial capture may work. Will still need a manual to do that.
I have a Gradeshift interface board - But the dualcom is 20 metres away in the attic to get signal.
Edited by PeteGBR
Removing the gateway module previously fault caused a line fault. I'm not familiar with the 2500 at all past testing the alarm at service. I doubt the line fault is returned back from the dualcom either. The gateway board is supposed to be an ethernet adapter but is probably causing the existing line fault. I want to remove it and I'm asking where in the menu's I can find the flag to stop the endstation looking for it.
