Help please
Hi all hoping someone on here can help and save me trying to get someone to fix this. We have had a new kitchen installed and the fitters cracked the sensor off the wall and ive got a new one can someone help me ?? which wires go where on the new one ?
The sensor on the left is the old one and the sensor on the right is the new one Pyronix KX10DP. Do i need a different PIR sensor ???
Any help would be greatly appreciated
GavinIMG_3114.thumb.jpg.5bcba97363b59b905b342ca622e60f95.jpgIMG_3113.thumb.jpg.2c12c1b17f7cc2c80f0352fe262abfc1.jpg
White and green to tamper terminals
Blue and yellow to alarm
Black is minus -
Red is positive +
18 minutes ago, scotslad469 said:
Lets pretend im stupid ?
What colour wires go into the pyronix terminals ??
And since ive cut the old one off now the panel is saying AUX DC fail ?? Am i better getting a pro into look at it ?
Aux DC fail because probably short it out
Black is minus -
Red is positive +
On the new PIR it has two connectors for Alarm and tamper one each with EOL above them what colour in the EOL screw
+ Red
- Black
Alarm EOL ?
Alarm ?
Tamper ?
Tamper EOL ?
thanks for all the help and patience and yes the glass fuse is blown I will replace it
+ Red
- Black
Alarm EOL ?
Alarm ?
Tamper ?
Tamper EOL ?
Same as what I just said
And ignore eol and don't put jumpers on them
I guess I could type it out but I am going to  be lazy , your just getting confused the word eol , ignore it , so then instructions are the same as what I said before
Blue and yellow to alarm terminals
Black is minus - terminal
Red is positive + terminal
Thanks for the help. I owe you a few of these ?????
5 minutes ago, MrHappy said:
I once did a job in Ardrossan.....
I believe the foreign office, issue the same advice to travelers as they do for mogadishu, apart from the sun screen ?
Mogadishu is safer to travel to than ardossan
  • Like 1
Thanks to all the replies.
PIR now working perfectly few issues I forgot I set the alarm to all the defaults so not knowing the default pin was #### i triggered the tamper and couldn’t shut it down but got it all done in the end.
Edited by sixwheeledbeast
no codes please
  • 2 weeks later...
Small bit further help. After getting the PIR sensor installed and working. I decided to do a walk test and see if everything was fine and which zones were which.
I believe these are shock sensors ? well i gave them a little nudge to see which zone they were in and now they flash red constantly. Anyone any ideas how to get them to stop flashing ???
I have set the alarm and unset it ive been into engineer mode and done a reset still they flash ALL NIGHT LONG !!
Any further help would be appreciated......
Personally I would only drop the power to the detectors.
I'm not sure with these panels but there will most probably be an output that resets on arm/set or something similar (pulse output perhaps?) that you can programme to drop the power momentarily on setting.
Worst case, you cold wire in a small unobtrusive switch to interrupt the 12v and mount it through the casing at the bottom or something.
