Hi guys, when i commission an intruder alarm i always take a closed loop cable resistance for every detector, but have been "advised"!!!?
By another engineer that he has spoken to inspectors who have told him that its fine to just record the zone, tamper res from the zone,ie whats shown on the keypad, i feel somones being a little idle,
Would love to see your views on this,and if anyone else feels this is also ok,?
Link to post
Share on other sites
claim to take cable readings from the device, along with voltage,
& continue to fill them out on the drive home.....
Mr😀 Veritas God
Link to post
The whole idea of meter readings is to check the the circuit is what its expected to be, so I would use a meter on the circuit. If its wired wrong or the wrong resistor has been used or there is short on the cable. You could meter a spare pair of wires but it wont pick up if you havent done the screws up on a door contact
Link to post
That's what subbies do to get paid for first fix
Link to post
Technically you need to record the resistance of the circuit wiring. If eol that means without resistors etc and definitely not from the uncalibrated panel.
Just as you need to do 70 on the motorway
securitywarehouse https://www.securitywarehouse.co.uk
Link to post
Resistance readings are pointless if your not testing only the pair without resistors. Double pole you would check through the sensor too but the values mean nothing if your measuring through EOL's.
What would be the point of having you meter calibrated if your taking reading from the panel. Who says the panel is accurate or will be accurate in the future.
Link to post
I heard that but, the whole point of meter readings is to spot if there is anything wrong with the installation, not just the cable. Testing with the resistors in-line will tell you there is something wrong in the same way that testing the cable will. Only it will also tell you; if you have a bad resistor, or if you have the resistors around the wrong way, or if a terminal is not done up tight enough. On top of that if you have a staple through the cable on the pair you have twisted together to meter you get a false reading. At the end of the day its about the working system imo, you trying to prevent having to come back the day after it was installed because its been going off all night.
Link to post
I agree with PJ but as a subby I would leave a spare pair twisted together in the device if available.
Link to post
3 minutes ago, norman said:
I agree with PJ but as a subby I would leave twisted
Link to post
Testing with a DMM with resistors in place is not going show useful values IMO. Resistors wrong way round you should be finding with normal walk testing as part of the other commissioning procedures.
Likelyhood of this is much lower with built in resistors becoming pretty standard.
Staple through a cable would fault on EOL and if DP the value wouldn't seem correct for the cable length and again you would be closed or tampered so would find that on a walk test.
When everything was DP having the devices contact resistance was useful but with EOL and built in its pointless for reference in the future.
Link to post
    No registered users viewing this page.
