Guest Posted June 23, 2020 Share Posted June 23, 2020 Hi. I have an Acorn Control Panel installed in my garage block from 1986 which apart from changed rechargeable batteries is still going strong. I have replaced the external bell box with a new box and sounder but the bell time is addressed by resistors and links that you cut on the PCB in the panel. Has anyone got a copy of the installation instructions from one of these very old panels. It was originally a Shorrock installation. Thanks Chris Quote Link to comment Share on other sites More sharing options...
PeterJames Posted June 23, 2020 Share Posted June 23, 2020 Hi Chris Are you sure that Acorn is the brand? In any case, we cannot give out installation instructions here. only user ones Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 23, 2020 Share Posted June 23, 2020 4 hours ago, Chris Covell said: Hi. I have an Acorn Control Panel installed in my garage block from 1986 which apart from changed rechargeable batteries is still going strong. I have replaced the external bell box with a new box and sounder but the bell time is addressed by resistors and links that you cut on the PCB in the panel. Has anyone got a copy of the installation instructions from one of these very old panels. It was originally a Shorrock installation. Thanks Chris Acorn might be installer Upload picture of keypad Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 23, 2020 Share Posted June 23, 2020 Shorrock and Acorn. Hmm, makes me recall some really old 2 zone key switch thing? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 23, 2020 Share Posted June 23, 2020 20 minutes ago, sixwheeledbeast said: Shorrock and Acorn. Hmm, makes me recall some really old 2 zone key switch thing? Model 76 / 77 Those had links for bell delay etc The old da for code changing was the old wire links used to be interesting to Quote Link to comment Share on other sites More sharing options...
PeterJames Posted June 23, 2020 Share Posted June 23, 2020 1 hour ago, sixwheeledbeast said: Shorrock and Acorn. Hmm, makes me recall some really old 2 zone key switch thing? Acorn makes me recall Acorn Antiques, there is a company Essex way (Clacton I think) called Acorn Alarms, the bloke doesn't believe in connecting bell tamper circuits up because they go off for no aparrent reason. I dread to think what his installs are like Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted June 23, 2020 Share Posted June 23, 2020 3 hours ago, sixwheeledbeast said: Shorrock and Acorn. Hmm, makes me recall some really old 2 zone key switch thing? Horrible tan colour front Do remember having the instructions for them once Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2020 Share Posted June 23, 2020 This is a picture of the panel - made by a company in Cornwall. Looked after, cared for and cleaned and working as the day it was put in... as it stands the bell output would sound continuously as the old sounder had a SAB or similar that timed out after 15 minutes. There are a series of resistors and links that set the exit/entry time, the bell time and the auto reset... It isnt clear which to cut for the bell time, hence the original question. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 23, 2020 Share Posted June 23, 2020 8 minutes ago, Chris Covell said: This is a picture of the panel - made by a company in Cornwall. Looked after, cared for and cleaned and working as the day it was put in... as it stands the bell output would sound continuously as the old sounder had a SAB or similar that timed out after 15 minutes. What tat have you purchased that does not have a cut off timer ? 2 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted June 23, 2020 Share Posted June 23, 2020 7 hours ago, PeterJames said: Hi Chris Are you sure that Acorn is the brand? In any case, we cannot give out installation instructions here. only user ones Not even for this old thing? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted June 23, 2020 Share Posted June 23, 2020 12 minutes ago, al-yeti said: Not even for this old thing? I dont make the rules..........well okay I do, but only some of them.........well okay this one in particular was one of mine..... but it is for good reason and all the mods agreed Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 23, 2020 Share Posted June 23, 2020 If the new external bell you have has a cut off timer then why mess about cutting resistors? Or have you fitted an equivalently aged C type without an SAB module now, for some odd reason? Oh that is the beige box I was thinking of yer. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 23, 2020 Share Posted June 23, 2020 1 hour ago, PeterJames said: I dont make the rules..........well okay I do, but only some of them.........well okay this one in particular was one of mine..... but it is for good reason and all the mods agreed Yeah I get you But there needs adjustment to alarms from certain era lol Surley a.single page showing bell links won't matter Ah forget it lol Quote Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2020 Share Posted June 24, 2020 Morning - some kind person has sent me a scanned document which is of the typed out installation and instructions which is just 2 sides of A4 showing the links to cut etc. The new bell box is Deltabell plus, but my local supplier said that he thinks the deltabell, would stop after 15 mins anyway but should sort the links out the make sure the panel cuts off and resets. The panel is simple and very reliable and built to last so not changing it! Man date was Feb 1985 according to its sticker inside ... not many 35 year old panels still going 9 hours ago, al-yeti said: Yeah I get you But there needs adjustment to alarms from certain era lol Surley a.single page showing bell links won't matter Ah forget it lol Thanks for your thought here - alot of other panel install/user instructions you can get as pdfs easily by searching the web, even the installation ones are fairly easy to get for Scantronic etc. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 24, 2020 Share Posted June 24, 2020 It's the bell that needs the cut off timer, it just became standard that all equipment would have the timer built in for reducing noise pollution. Even if the panel continues to provide a bell trigger output the bell would ignore it until removed and reapplied. Unless there is some rearm function as part of this then I'd still say leave it alone myself. It's part of our guidelines not to provide engineers manuals here, not only from a security perspective but copyright issues. What other sites distribute is up to them. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 24, 2020 Share Posted June 24, 2020 1 hour ago, Chris Covell said: Morning - some kind person has sent me a scanned document which is of the typed out installation and instructions which is just 2 sides of A4 showing the links to cut etc. as normal, you got better advice for free on here 1 hour ago, Chris Covell said: The new bell box is Deltabell plus, but my local supplier said that he thinks the deltabell, would stop after 15 mins anyway but should sort the links out the make sure the panel cuts off and resets. than here where you spent £ 1 hour ago, Chris Covell said: The panel is simple and very reliable and built to last so not changing it! Man date was Feb 1985 according to its sticker inside ... not many 35 year old panels still going There's loads of old crap out there, often the the alarm controls are decades older than everything else in the house. You can do what you want with it but are unlikely to find many people willing to work with it. 1 hour ago, Chris Covell said: Thanks for your thought here - alot of other panel install/user instructions you can get as pdfs easily by searching the web, even the installation ones are fairly easy to get for Scantronic etc. Gosh who'd have thought stuff produced in PDF formats is readily available to anybody.... 1 hour ago, sixwheeledbeast said: It's part of our guidelines not to provide engineers manuals here, not only from a security perspective but copyright issues. What other sites distribute is up to them. years ago solicitors where threatening to sue TSI over there manuals being on here, thats the main reason why we don't share 'em Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2020 Share Posted June 24, 2020 1 hour ago, MrHappy said: Gosh who'd have thought stuff produced in PDF formats is readily available to anybody.... Being Autisitc - Mr Happy, I dont take sarcasm well - just saying! Just asking for help on this post as I was stuck. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 24, 2020 Share Posted June 24, 2020 59 minutes ago, Chris Covell said: Being Autisitc - Mr Happy, I dont take sarcasm well - just saying! Just asking for help on this post as I was stuck. Ok , but reality this panel is now an antique and junk to most But great for DIY while it works perhaps Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 24, 2020 Share Posted June 24, 2020 1 hour ago, Chris Covell said: Being Autisitc - Mr Happy, I dont take sarcasm well - just saying! equality... If you was a one legged, lesbian, black, midget you'd get no different treatment from me 1 hour ago, Chris Covell said: Just asking for help on this post as I was stuck. assuming your an adult, you should have the ability to understand over the length of your life the world changes slowly significantly. eg in 1986 if I wanted an instruction book for alarm panel I'd have to telephone the manufacturer & they might have been kind enough to send one in the post. 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted June 24, 2020 Share Posted June 24, 2020 30 minutes ago, MrHappy said: equality... If you was a one legged, lesbian, black, midget you'd get no different treatment from me assuming your an adult, you should have the ability to understand over the length of your life the world changes slowly significantly. eg in 1986 if I wanted an instruction book for alarm panel I'd have to telephone the manufacturer & they might have been kind enough to send one in the post. In those days you would get it quite quick aswell Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 24, 2020 Share Posted June 24, 2020 1 hour ago, al-yeti said: In those days you would get it quite quick aswell because RM had really fast sherpa vans & no tat from ebay.... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
STRAK Posted March 6, 2023 Share Posted March 6, 2023 Acorn is the model, Shorroks the manufacturer. I installed 100s of them. A firm called Security Equipment Sales sold them (It was actually part of Shorroks). Quite a good 2 zone control panel in its day . Made of steel and you needed the key to open it. Logic gate inputs and and had a nice little input filter on the zones of about 0.8 seconds to change state if I remember correctly, that really cut down on false alarms from poor wiring connections. Designed for domestic properties but was useful for small shops and offices too. Quote Link to comment Share on other sites More sharing options...
STRAK Posted March 6, 2023 Share Posted March 6, 2023 4 minutes ago, STRAK said: Acorn is the model, Shorroks the manufacturer. I installed 100s of them. A firm called Security Equipment Sales sold them (It was actually part of Shorroks). Quite a good 2 zone control panel in its day . Made of steel and you needed the key to open it. Logic gate inputs and and had a nice little input filter on the zones of about 0.8 seconds to change state if I remember correctly, that really cut down on false alarms from poor wiring connections. Designed for domestic properties but was useful for small shops and offices too. PS - They were made in white but an option of Brown and Beige too Quote Link to comment Share on other sites More sharing options...
