honeywell tamper issue
44 minutes ago, Rekusu said:
It is mine; I installed the system and set it up when I built the house
Its DIY tat, maybe if you got you had in you pocket & bought something decent in the 1st place....
1 hour ago, Rekusu said:
Knew it!  Purists.
Not saying it is the most elegant solution, but this RKP is in the garage so am not overly concerned with the appearance.  I could certainly have done a better job with taps and dies, etc, but don't have access to those tools.
Yes, it is not the most expensive alarm but what does one get for more money?  Ass an alarm, it works, it activates the sounder when triggered; what more do I want?  The electronics are fine, they do what they say on the box so why should anyone have to spend £25 just to get a new case?  And only because the case is poorly designed.
The control box plastic case is much better designed with the plastic tabs being stronger.
But I do agree that fixing the issue may not be everyone's cuppa.  It is mine; I installed the system and set it up when I built the house
No need to justify
I fixed one today and added a gsm unit , no bother.....
Case design is good , it's you lol
  • 11 months later...
