Sideshow Posted May 29, 2020 Author Share Posted May 29, 2020 Definitely checked and heard the outside bell Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 29, 2020 Share Posted May 29, 2020 Just now, Sideshow said: Definitely checked and heard the outside bell Ok so how did you activate it. IIRC on the eurosec the bell can be delayed on certain activations, ie timeout. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
kwc Posted May 29, 2020 Share Posted May 29, 2020 Set the system and trip a NON exit entry zone. This should sound the bell. if working on bell test then can only be there is a bell delay set or tripping an entry timed zone and not waiting until full entry time has expired. Quote Link to comment Share on other sites More sharing options...
aissecur Posted May 31, 2020 Share Posted May 31, 2020 On 29/05/2020 at 18:56, kwc said: Set the system and trip a NON exit entry zone. This should sound the bell. if working on bell test then can only be there is a bell delay set or tripping an entry timed zone and not waiting until full entry time has expired. You need to check the zine you trigger is programmed as a 12hr (ie instant alarm on zone) failing that press & hold 1 & 3 on the remote keypad to activate the panic, this will give you a full alarm condition Quote Link to comment Share on other sites More sharing options...
