Eurosec Alarm System - siren / wiring issues
Hi, After some help.
I have 10 year old Eurosec alarm system,  and when i went to change the internal battery i noticed a loose Blue wire, which i believe is the Trigger wire from the external alarm?.
Any idea were this should connect to? I have also noticed that the external alarm has stopped working.
If you want to keep your system operational I do hope you change your battery more often than once every 10years
