AgsDave Posted May 5, 2020 Share Posted May 5, 2020 Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 5, 2020 Share Posted May 5, 2020 2 hours ago, AgsDave said: Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 5, 2020 Share Posted May 5, 2020 I assume if shows open its needs a resistor or link in the terminal too Quote Mr Veritas God Link to comment Share on other sites More sharing options...
james.wilson Posted May 6, 2020 Share Posted May 6, 2020 Is it well old? Might need a restart if the circuit was in use, then went fault before spared off Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Nova-Security Posted May 6, 2020 Share Posted May 6, 2020 Airitechs need to see a 4k7 EOL even if the circuit is programmed as unused. 2 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
AgsDave Posted May 6, 2020 Author Share Posted May 6, 2020 I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. 19 hours ago, al-yeti said: You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal No it wouldn't set. I prefer galaxy all day long. But I guess it's what you get used too. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted May 6, 2020 Share Posted May 6, 2020 Only ever serviced a couple of Aritechs never made any changes, didn't know that about resistance req. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
AgsDave Posted May 6, 2020 Author Share Posted May 6, 2020 4k7 alarm and tamper. Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted May 6, 2020 Share Posted May 6, 2020 2 hours ago, AgsDave said: I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. Airitech need the 4K7 EOL if the zone isnt used, not like a Galaxy where you can spare it with nothing in the zone Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
abbz Posted May 6, 2020 Share Posted May 6, 2020 (edited) On the older ones there were 2 attributes called unused. Never remember having to put resistor in unused cct Edited May 6, 2020 by abbz Quote Link to comment Share on other sites More sharing options...
