AgsDave Posted May 5, 2020 Share Posted May 5, 2020 Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 5, 2020 Share Posted May 5, 2020 2 hours ago, AgsDave said: Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 5, 2020 Share Posted May 5, 2020 I assume if shows open its needs a resistor or link in the terminal too Quote Mr Veritas God Link to comment Share on other sites More sharing options...
james.wilson Posted May 6, 2020 Share Posted May 6, 2020 Is it well old? Might need a restart if the circuit was in use, then went fault before spared off Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Nova-Security Posted May 6, 2020 Share Posted May 6, 2020 Airitechs need to see a 4k7 EOL even if the circuit is programmed as unused. 2 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
AgsDave Posted May 6, 2020 Author Share Posted May 6, 2020 I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. 19 hours ago, al-yeti said: You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal No it wouldn't set. I prefer galaxy all day long. But I guess it's what you get used too. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted May 6, 2020 Share Posted May 6, 2020 Only ever serviced a couple of Aritechs never made any changes, didn't know that about resistance req. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
AgsDave Posted May 6, 2020 Author Share Posted May 6, 2020 4k7 alarm and tamper. Quote Link to comment Share on other sites More sharing options...
Nova-Security Posted May 6, 2020 Share Posted May 6, 2020 2 hours ago, AgsDave said: I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. Airitech need the 4K7 EOL if the zone isnt used, not like a Galaxy where you can spare it with nothing in the zone Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
abbz Posted May 6, 2020 Share Posted May 6, 2020 (edited) On the older ones there were 2 attributes called unused. Never remember having to put resistor in unused cct Edited May 6, 2020 by abbz Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 6, 2020 Share Posted May 6, 2020 1 hour ago, Logan said: My favourite galaxy is the microtech galaxy 60 i just wish the galaxy made more tones than just a single tone beep It does that to allow full flexibility. You can use anything then off an output. All tones or leds or buzzers or hilos or etc etc same throughout. Other panels tried it with speaker out but missed the fact it isn't a limitation Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted May 7, 2020 Share Posted May 7, 2020 3 hours ago, Logan said: I haven't tried the newer galaxy but I LOVE the menus and the amount of things you can do with it i may switch to galaxy soon just wish the end station is smaller Switch to galaxy from what? And to which galaxy? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 7, 2020 Share Posted May 7, 2020 Big end station is one thing I love, more room for comms etc Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
norman Posted May 7, 2020 Share Posted May 7, 2020 Yeah, and the sign of a proper commercial panel imo (where space and aesthetics come second to function) Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
MrHappy Posted May 7, 2020 Share Posted May 7, 2020 An end station which is big enough to produce an echo is ideal... 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted May 7, 2020 Share Posted May 7, 2020 1 hour ago, Logan said: Galaxy 60 from pyronix Lol ok thought you meant on installs, you mean for shed? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 7, 2020 Share Posted May 7, 2020 28 minutes ago, Logan said: No for my installs im going to be doing a small shop soon with a sterling 10 (ill be removing the sterling 10 with a hammer) i think I cmay use galaxy (ill probably try the dimension) So your going to try a dimension ? Instead of galaxy 60 for your installs ? Where you buying the galaxy 60 Thought you signed up with orisec? And used euro mini? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 7, 2020 Share Posted May 7, 2020 17 minutes ago, Logan said: I use orisec for bell boxes and pirs from orisec And have idea to switch to galaxy 60 for installs yes? Or dimension? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 7, 2020 Share Posted May 7, 2020 @Loganchoose 1 product & fit lots of it, even at you pocket money labour rate, you not going to be able to put a G2 on every job unless the product comes from bin dipping Quote Mr Veritas God Link to comment Share on other sites More sharing options...
