Grade 3
From what I remember the wording is along the lines of "non system operators should not be given any indication of coverage or status from the CIE or detection devices" There is a caveat that the user or engineer can activate these indications for testing but after 120s of leaving the test it returns back to off/banner message.
This is mandatory at Grade 3 and recommended based on risk for Grade 2 IIRC.
  • Replies 29
  • 2 months later...
On 23/04/2020 at 23:16, al-yeti said:
All grade 3 must be anti mask?
What if you are adding kit to the grade 3 system that isnt grade 3? Perimeter beams for instance? Told its ok we need to right a deviation, makes no sense to me where someone can open a grd3 door contact then break an ungraded beam, ? Is this still a confirmed alarm
The Grade of a system is defined by the lowest graded component so if you fit a grade 2 component the system will be G2
Yes i understand that, im talking kit that cant be graded,
We done a job and had to fit perimeter beams around perimeter,  because the beams where not graded, we where told we could keep at as grd3 but need to do a deviation explaining no other devices at a graded level where available,
Also finding some breakglass detectors are xlaiming ro be g3 by there model number but are infact grade 2 etc
