HKC - GSM - Q Unit - What's a "System Fault" ?
I've just installed a HKC GSM - Q unit in my panel. SMS options allow the reporting of "System Faults". I thought this might include mains failure, but it doesn't when the option is set to "yes".
Is a "system fault" loss of battery power to the board and some other things?
Edited by Eugene's DIY Den
Are all the fault reporting checked yes
Mains
Communication
Etc all in one section
Mains
Communication
I don't get any SMS notification on mains failure.
Ok but it's not what I asked you , just going through what it could be
I will try it out for you if I can later
In the SMS - Phone options menu:
Report alarm yes
Report system fault yes
Report device yes
Report test yes
All the others are set to no.
2 hours ago, james.wilson said:
There is a delay timer on mains failure
Ok, they don't mention it in the GSM unit installation manual, I'll check the panel manual.
55 seconds by default according to the manual, however the panel starts beeping a few seconds after loosing power and when I enter the code it tells me about the fault. I may have changed the setting or maybe this is the reporting delay before an SMS is sent?
