Replace Paragon plus with new version
I cannot get access to the bell at the moment, however i have not changed the connections there, I labelled where it was wired into the original panel. (note i need to reduce the exposed wires in the picture)
B+: Red
B- Black
BA : yellow
STB- : Green
STB+: White
BT: Blue
Did you change anything other than the bell? I would start by removing the strobe and bell (yellow and white wires) then see if arming still blows the fuse then put them back one at a time to see whats causing the problem. My money is on strobe
B+: Red
B- Black
BA : yellow
STB- : Green
STB+: White
BT: Blue
you've wired the strobe wrong...
