Replace Paragon plus with new version
8 hours ago, sixwheeledbeast said:
If you go Texecom then use a Premier 24 Poly not an Excel
Thanks, i will look into this one.
5 minutes ago, Logan said:
Do you use the remote keypad the most or the panel keypad the most
We will be using the keypad the most as the panel is hidden
1 hour ago, Logan said:
For some reason my premere only seems to accept EOL
Reality you don't know jack , let alone alarms
i worked on tons of panels even ones from the 1980s
Most of them faulty
  • Upvote 1
Does any one know if there should be any issues with using the paragon wiring and external siren with the Pyronix Euro 46 (Note i do not want to use EOL for ease of fitting) . And when you purchase the Pyronix does it come with full instructions as there are limited downloads on the internet
I want to use the same PIR's as well.
10 minutes ago, Logan said:
Yes the 46 includes the install, programming and user guide
Your bell box should be compatable  (you can attach a picture if you want so i can verify that it is compatable)
I believe the recall was for communication to ARC (alarm receiving centre)
Thanks for the info, I will get a picture tomorrow.
I assume the recall was just a firmware update in the end?
Do you believe the PIR's should be OK?
Hi Logan
I have attached the bell box picture, I want to use this to start, with the aim of replacing it later in the year.
1 other question, do you need to be an installer to use the home control app on Pyronix?
