Steve 1968 Smith Posted January 7, 2020 Share Posted January 7, 2020 Anybody able to advise? We currently have 2 entry/exits with 9930s but have a 3rd entrance where we'd like to fit another keypad and create a 3rd entry/exit. Is it possible? And is there a way of doing this 3rd entry/exit without cabling back to the 9651? Cheers, Steve Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 7, 2020 Share Posted January 7, 2020 22 minutes ago, Steve 1968 Smith said: Anybody able to advise? We currently have 2 entry/exits with 9930s but have a 3rd entrance where we'd like to fit another keypad and create a 3rd entry/exit. Is it possible? And is there a way of doing this 3rd entry/exit without cabling back to the 9651? Cheers, Steve Well you still need to have a contact or PIR for entry exit so have to wire back , unless there's another detector nearby with spare pairs Quote Link to comment Share on other sites More sharing options...
Steve 1968 Smith Posted January 7, 2020 Author Share Posted January 7, 2020 Thanks for that - we've got 2 radio expanders fitted (all the PIRs are wireless) - can I link to spare channels wirelessly? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 7, 2020 Share Posted January 7, 2020 5 minutes ago, Steve 1968 Smith said: Thanks for that - we've got 2 radio expanders fitted (all the PIRs are wireless) - can I link to spare channels wirelessly? Now I confused how you got two wireless expanders on a 9651..... Better wait for mr DD Either way if you have spare wireless channels then you can get a radio contact for the door aswell I.assumingnyou actually have a 9571/2 Quote Link to comment Share on other sites More sharing options...
Steve 1968 Smith Posted January 7, 2020 Author Share Posted January 7, 2020 Good point. The manual says 9x5x, but having looked closer it says 9853/9752/9751.. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 8, 2020 Share Posted January 8, 2020 I am guessing you have a 9752 or 9853 - is it a square main system case or an oblong one? The 9930 keypad is obselete, but a 9941 or better yet 9943 if you want fob will do the same job. You'll have to wire the keypad, of which you can have 4, back to the nearest other keypad, expander, or the panel. The keypad only uses 4 wires so assuming it's all done in 6 or 8 core wire, you could use the spare, as long as they aren't already in use, for the EOL door contact. Or, as it's already a wireless system, add another wireless door contact? Even the newest Eaton slim RF door contact will work with an older system. (You could even add an expander if you are wiring to the nearest expander or keypad, but seems a lot for just one zone, and it would have to be the larger 9853 system for there to be 'room' for it) Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
al-yeti Posted January 8, 2020 Share Posted January 8, 2020 17 minutes ago, datadiffusion said: Even the newest Eaton slim RF door contact will work with an older system. Good that Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 8, 2020 Share Posted January 8, 2020 Well, yeah but no but yeah I wish it didn't (at least, not without flicking a switch...) and the RF was 2 way as the i-on has been capable of since launch! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Steve 1968 Smith Posted January 8, 2020 Author Share Posted January 8, 2020 Many thanks for your advice, and for al-yeti's. The main system case is square. You've been great, I think I've got enough info to give it a go! Biggest faff is running the wire across the house. Thanks again for your quick and insightful responses :) Steve 56 minutes ago, datadiffusion said: I am guessing you have a 9752 or 9853 - is it a square main system case or an oblong one? The 9930 keypad is obselete, but a 9941 or better yet 9943 if you want fob will do the same job. You'll have to wire the keypad, of which you can have 4, back to the nearest other keypad, expander, or the panel. The keypad only uses 4 wires so assuming it's all done in 6 or 8 core wire, you could use the spare, as long as they aren't already in use, for the EOL door contact. Or, as it's already a wireless system, add another wireless door contact? Even the newest Eaton slim RF door contact will work with an older system. (You could even add an expander if you are wiring to the nearest expander or keypad, but seems a lot for just one zone, and it would have to be the larger 9853 system for there to be 'room' for it) Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 9, 2020 Share Posted January 9, 2020 No radio on board it's metal cased! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Steve 1968 Smith Posted March 11, 2020 Author Share Posted March 11, 2020 On 08/01/2020 at 08:51, datadiffusion said: I am guessing you have a 9752 or 9853 - is it a square main system case or an oblong one? The 9930 keypad is obselete, but a 9941 or better yet 9943 if you want fob will do the same job. You'll have to wire the keypad, of which you can have 4, back to the nearest other keypad, expander, or the panel. The keypad only uses 4 wires so assuming it's all done in 6 or 8 core wire, you could use the spare, as long as they aren't already in use, for the EOL door contact. Or, as it's already a wireless system, add another wireless door contact? Even the newest Eaton slim RF door contact will work with an older system. (You could even add an expander if you are wiring to the nearest expander or keypad, but seems a lot for just one zone, and it would have to be the larger 9853 system for there to be 'room' for it) Many thanks @datadiffusion, finally got around to doing this on my 9752, fitting a 3rd keypad and a wired door contact as you suggested. Your advice much appreciated :) 1 Quote Link to comment Share on other sites More sharing options...
