imroberts Posted December 22, 2019 Share Posted December 22, 2019 I moved house earlier in the year and inherited a Eurosec CP8L, however no codes. I've downloaded the installation and user manuals and factory reset the unit so I can now get into the installer options. I've worked through all the options and set up the zones as I want them etc. and everything is working as I expect. I have a few questions however that aren't completely clear from the manual and hope somebody can help. Exit Modes I've set appropriate times and set this to Time for both Full and Part - what's the behaviour if I select T/EE, ET or E/E?Entry 1 Time and Entry 2 Time These are set to 30 and 10 by default which match the Full Exit and Part Exit times however it's not clear what Entry 1 and 2 refer to? Tamper Ring This is set to Off by default - does this mean the alarm won't go off in the event of a tamper being triggered? It strikes me as odd that would be off by default? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted December 22, 2019 Share Posted December 22, 2019 15 minutes ago, imroberts said: T/EE, ET or E/E? T/EE = timed exit or final door terminate. final door means setting will complete when the final door is closed on leaving ET = exit terminate. Push to set button. Wont set till its pressed EE = final door 17 minutes ago, imroberts said: Entry 1 Time and Entry 2 Time Entry 1 normal entry time, on expiry entry 2 time will start but will give an internal alarm. At the expiry of timer 2 full alarm (Bells and comms) 18 minutes ago, imroberts said: Tamper Ring I dont know but id assume it will fire the external bells when disarmed if on. Default would be internal alarm only for tampers if disarmed 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted December 22, 2019 Share Posted December 22, 2019 Tamper Ring as above it activates the bell trigger if the bell tamper is opened it's a Gardtec thing. Most systems would let the SAB deal with self activating which is the same as off. Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted December 22, 2019 Share Posted December 22, 2019 1 hour ago, sixwheeledbeast said: Tamper Ring as above it activates the bell trigger if the bell tamper is opened it's a Gardtec thing. Most systems would let the SAB deal with self activating which is the same as off. Never noticed that feature, how odd. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
