Bosch hybrid Dvr with Hik cameras
Sirtoddius
Hi
has anyone had any experience adding Hik ip cameras to a hybrid Bosch divar 3000. They are both the same onvif profile, I’ve enabled onvif on the cameras but can’t get them to be seen on the Bosch Dvr. I’ve tried dhcp and I’ve tried assigning both ip addresses in the same range but I can’t get them on.  Bosch have said they can’t help as they don’t offer support for adding non Bosch cameras.
1 hour ago, Sirtoddius said:
Hi
Did you check the onvif port the cameras are using , the profile like s profile is a seperate issue
You may need to manually enter the port
  • Upvote 1
  • 4 weeks later...
