Logan
Fire alarm isolator
16 hours ago, Logan said:
NOTHING replaces a good metal panel
Yeah but for me Fike usually replaces a bad metal panel
Share this post
Link to post
Share on other sites
Whats your bad metal panels?
Im personally looking for a precipt fire panel
Share this post
Link to post
Broken ones!
  • Thanks 1
Share this post
Link to post
Just now, datadiffusion said:
Broken ones!
Lol.   Do you know anything about the mf200?
Share this post
Link to post
Not much TBF, might have always chosen Scanny intruder but never really went with Menvier for fire, fitted a few JSBs in the past.
  • Upvote 1
Share this post
Link to post
It has a issue with the power supply.  I have bought a new transformer for it.  I plan to install it in my shed
Share this post
Link to post
I've never seen a conventional head lit up yellow-
Resetting extingushed the yellow light & reset the zone fault light (mf400)
Mr:)
Share this post
Link to post
Yellow means fault. It also opens the zone 20200102_095144.thumb.jpg.a74a983ee8c7d845aeab1841646f0de0.jpg    What happened here.  Why is it INSIDE the wall
Share this post
Link to post
A shopfitter has wall boarded after the sensor has been fitted...
Mr:)
Share this post
Link to post
Yellow means chamber fault/drift compensation limit
Its a MPD821 advance series
Share this post
Link to post
Using my years of experience.... I just knew it where f@~#ed
Mr:)
Share this post
Link to post
Not as bad as this one.
Are you ripping the mf400 out?
Share this post
Link to post
Not yet,
Mr:)
Share this post
Link to post
Posted (edited)
9 minutes ago, MrHappy said:
Not yet,
My mf200 has a strange issue where the panel wont reset the sounders after a activation of a zone and resetting a call point.   The only way to reset is to disconnect power and reconnect power
Edited by Logan
Share this post
Link to post
49 minutes ago, MrHappy said:
Using my years of experience.... its f@~#ed
  • Thanks 2
  • Upvote 1
Mr:)
Share this post
Link to post
I will try replacing the relay to see if that fixes it
Share this post
Link to post
2 minutes ago, james.wilson said:
You are silencing first?
Already tried. The relay gets stuck on. Only way to reset it is turning the power off then on again
Share this post
Link to post
Sounds good , if it works cheap fix
  • Thanks 1
Share this post
Link to post
@MrHappy. I have wired the isolator to my sheds fuse box.  In the regulations it says you need to put the panel on a non RCD protected circuit. However my sheds fuse box has a RCD
And yes i installed thos fuse box
Edited by Logan
Share this post
Link to post
Keep RCD in your case for shed
Share this post
Link to post
59 minutes ago, Logan said:
@MrHappy. I have wired the isolator to my sheds fuse box.  In the regulations .......And yes i installed thos fuse box
grey earth . black neutral ?
Mr:)
Share this post
Link to post
RCD from 2019, MCBs from 1989!
The regs discourage the use of 'new colour' black as neutral to avoid confusion with the previous colours.
They recommend that grey is used as Neutral with appropriate sleeving whenever a 3 core / 3 phase 'new' colour cable is used for e.g. a fan isolator or SWA supply etc...
Share this post
Link to post
Its the previous sheds cable colour code they used code    i put blue sleeve on the neutral.  I have the fire alarm panel wired into the 6a lighting circuit
Share this post
Link to post
Muppets undone themselves with the grey black thing lol
Share this post
Link to post
    No registered users viewing this page.
