Logan
Fire alarm isolator
7 minutes ago, james.wilson said:
but a terminal will remove the fuse
How it has security screw takes time to get it out with ease?
3 minutes ago, MrHappy said:
snake eyed ;)
Oh you beat me to it...
Share this post
Link to post
Share on other sites
Ideal world, you have one of these https://www.cef.co.uk/catalogue/products/45781-fire-alarm-switch taken from DB1 (which would normally be in a locked mains room)
Wire to your keyswitch/isolation point adjacent (bush/coupled) to controls all with enhanced cable.
Life isn't always ideal and you have a shed. It's own suitable circuit from your shed board would do.
  • Thanks 2
Share this post
Link to post
Thanks
Share this post
Link to post
There can only be "one"
Share this post
Link to post
My ocd is going mad with the sticker...
Share this post
Link to post
Heres what the system looks like.  Tell me if somethingis not complimentso i can fix it
Share this post
Link to post
14 minutes ago, james.wilson said:
difficult to say but plastic fixings for a start
Unfortunately that is one thing i won't be able to fix all i have is 25mm conduit
Share this post
Link to post
If your aspiring perfection...
As above plastic mountings, metal hospital saddles would do.
Conduit most likely over filled (45% cable/55% space max.)
Smoke detector too close to light fitting.
MCP missing female end.
Fire alarm panel is missing...
Share this post
Link to post
No cover on mcp
1 hour ago, james.wilson said:
This is what we use I checked
Don't use many fike but do like 'em
Mr:)
Share this post
Link to post
22 minutes ago, MrHappy said:
No cover on mcp
Electrician favourite around here loads of them
Pros or bigger company's seem to use the advance range allot
Share this post
Link to post
Lol
Share this post
Link to post
39 minutes ago, james.wilson said:
All I use now
Bet you don't sell many Duonet's ?
Mr:)
Share this post
Link to post
27 minutes ago, sixwheeledbeast said:
Can't stand the bloody things or the crap detectors either.
what do you prefer ?
Mr:)
Share this post
Link to post
Alarmsense - proper detection you can actually replace with the sticks and are way more reliable
I don't mind the Sigma or there's C-Tec if you like your plastic.
Share this post
Link to post
not a fan of Alarmsense, Twinwire is better & std s65 heads
Mr:)
Share this post
Link to post
NOTHING replaces a good metal panel
Share this post
Link to post
19 minutes ago, sixwheeledbeast said:
 Never had any issues with either Alarmsense
sounding with no fire detected
Mr:)
Share this post
Link to post
Seems like every day at our school when kids jusjust want to make sure it works
Share this post
Link to post
Thought alarmsense was ctec ?
Share this post
Link to post
Alarmsense is Apollo they have two wire gear that others make controls for.
Sag-wire you have conversion bases and use conventional gear.
Share this post
Link to post
    No registered users viewing this page.
