Logan
Fire alarm isolator
For a system im doing (just for fun)  would a fused spur with "fire alarm panel do not switch off with a 3a fuse be ok  or will i need something like this
Share this post
Link to post
Share on other sites
a plug top would be good enough for a "just for fun system"
  • Like 1
  • Thanks 1
  • Upvote 1
  • Downvote 1
Mr:)
Share this post
Link to post
Well i just wanted it to look more professional.
  • Like 1
Share this post
Link to post
I am not entirely convinced those keyswitch chink jobs have actually been tested to any meaningful standard myself.
In terms of isolation, even MK bottle it with the keyswitch thing; theirs (which is what I fit) as a plastic, totally isolated affair where a keyswitch just makes a plastic disc switch a reverse-mounted, hidden gridswitch
(can I find a pic, can I bollox...)
  • Upvote 1
Share this post
Link to post
Why not use the metal boxes , screwed security type fuse hold and fish key slot on same 1gang plate  for testing
You get me?
Share this post
Link to post
Yeah have done that before too
Share this post
Link to post
15 minutes ago, james.wilson said:
Need key isolate and indication and double pole switch
Thanks
Share this post
Link to post
6 minutes ago, james.wilson said:
As a hobbyist can you get to read the relevant standards?
This is what ive been working on.  Waiting to get a fire panel.  I got a labelled fuse spur but i thought it was probably not compliment
Edited by Logan
Share this post
Link to post
1 minute ago, james.wilson said:
Your right it isnt
The label is for the consumer unit
Also using used old colour code FP200 that i ripped out of a building getting demolished
Share this post
Link to post
But it's just a label put in the wrong place.
You can see why some get annoyed. There are so many people doing this sort of stuff assuming they know the regs. BTW when you go 24v you need 300mm fixings, you still need fire proof fixings but the distance isn't defined
I'm not sure 2nd cable is OK but I'm not sure as it's nothing I'd consider.
securitywarehouse https://www.securitywarehouse.co.uk
Share this post
Link to post
Ok. I plan to get a menvier mf200 (used) from a building renovation. Have no clue if the panel will work when i get it
Edited by Logan
Share this post
Link to post
Just now, james.wilson said:
Again that's fine as a play thing
I dont know if it will work with a devices i have. I think the panel is 12 volt instead of 24 volts
Share this post
Link to post
11 minutes ago, sixwheeledbeast said:
Some small Menvier stuff had 12v standby, but still 24v
I think you're right
358 (1).pdf
Edited by Logan
Share this post
Link to post
Doesn’t need to be double pole anymore, single pole secret keyswitch will do as long as it’s marked up fire alarm do not switch off
Share this post
Link to post
This is what annoys me.    How many fails can you see?  Also not to mention the TS900 keypad and sounder that has been ripped off the wall (yes its still live)
Edited by Logan
Share this post
Link to post
Oh, so normal fused spur then will do?
Share this post
Link to post
1 minute ago, Shaunb1905 said:
No, has to have a special tool. So spurs are no good as no special tool is required
Like the one above the panel?
Share this post
Link to post
Fishtail Spur.
Share this post
Link to post
    No registered users viewing this page.
