Pilotech Posted December 16, 2019 Share Posted December 16, 2019 Hi, I have a Flex20 and just got my hands on a slightly second hand CP045 Touchcenter. Trouble is, It defaults to French and when powering up, it should take me to the addressing page so I can get it to talk properly with the Flex. Unfortunately, it doesn't come up with that - just straight to the home page. Anyone any ideas how to factory reset it so I can set the address (and language)? TIA Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted December 16, 2019 Share Posted December 16, 2019 Zut allors, cet Touchcenter est possible voler a ADT par ebay de france, correctament? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
datadiffusion Posted December 16, 2019 Share Posted December 16, 2019 (edited) Try 'stolen from' rather than 'fly to' Edited December 16, 2019 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
datadiffusion Posted December 16, 2019 Share Posted December 16, 2019 Ask yourself why we still have Carphone Warehouse at the same time Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
al-yeti Posted December 16, 2019 Share Posted December 16, 2019 3 hours ago, Pilotech said: Hi, I have a Flex20 and just got my hands on a slightly second hand CP045 Touchcenter. Trouble is, It defaults to French and when powering up, it should take me to the addressing page so I can get it to talk properly with the Flex. Unfortunately, it doesn't come up with that - just straight to the home page. Anyone any ideas how to factory reset it so I can set the address (and language)? TIA Didn't know touch center works with a flex? Galaxyguy? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted December 16, 2019 Share Posted December 16, 2019 Yes it does - only one possible though. And they are not stolen, they are customer returns. ADI global and others seem to offload these by the pallet and they end up on eBay for spares repairs state untested or unknown. Ok if you don't mind testing for a few weeks and are ready to take the hit if there's a fault. Quote Link to comment Share on other sites More sharing options...
Gordon Smith Posted December 18, 2019 Share Posted December 18, 2019 (edited) Press the padlock button on home screen, enter Engineer code, press bottom right button, press middle right button, then there is a small text button just off center, probably says somthing similar to 'language' but more gallic sounding! Also worth buying these if they are for your own use Edited December 18, 2019 by Gordon Smith spelling Quote Link to comment Share on other sites More sharing options...
norman Posted December 24, 2019 Share Posted December 24, 2019 On 16/12/2019 at 19:16, GalaxyGuy said: OK if you don't mind testing for a few weeks and are ready to take the hit if there's a fault. And fitting second hand gear with no provenance... Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
robbo173 Posted March 19, 2020 Share Posted March 19, 2020 Did anybody find a solution to this? I have the same issue with a CP045 that I recently purchased! Quote Link to comment Share on other sites More sharing options...
robbo173 Posted March 19, 2020 Share Posted March 19, 2020 Mines spanish! Take that as a no? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted March 19, 2020 Share Posted March 19, 2020 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
robbo173 Posted March 19, 2020 Share Posted March 19, 2020 The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 19, 2020 Share Posted March 19, 2020 31 minutes ago, robbo173 said: The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how? Do you have English version instructions? Quote Link to comment Share on other sites More sharing options...
robbo173 Posted March 19, 2020 Share Posted March 19, 2020 Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button! Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 19, 2020 Share Posted March 19, 2020 1 hour ago, robbo173 said: Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button! Can you upload some picture of the unit Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 20, 2020 Share Posted March 20, 2020 OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center. If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 20, 2020 Share Posted March 20, 2020 20 minutes ago, GalaxyGuy said: OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center. If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer. All available online though Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 20, 2020 Share Posted March 20, 2020 Yes, Honeywell now post some firmware releases to: https://www.security.honeywell.com/uk/resources/technical-support/software-upgrades/galaxy-software-download-centre No support if you brick your devices though. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted March 20, 2020 Share Posted March 20, 2020 Interesting that they have there firmware on a public FTP. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 20, 2020 Share Posted March 20, 2020 12 minutes ago, sixwheeledbeast said: Interesting that they have there firmware on a public FTP. They don't care And still no one has bought them ..... Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 20, 2020 Share Posted March 20, 2020 Not much to be gained from the firmware files unless the design is secured by obscurity. Oh, wait... Seriously though, it would be pretty hard to keep these things out of the public domain these days. The touch screen displays are a bit of an expensive gimmick anyway. And why would you want to look at CCTV cameras on an alarm keypad in a hallway Etc. when you can do the same on your phone. Someone on one of the Facebook forums posted a pic of a new Honeywell commercial security range. I cannot remember the name, but it looked quite different to any of the Galaxy products of yesteryear. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted March 20, 2020 Share Posted March 20, 2020 (edited) Just find it unusual, a lot of manufacturers try to distribute there firmware on a need to know basis, to make it harder to access. They are maybe concerned that someone could RE it and find some exploit, I am not saying it's a good or bad thing just unusual. I suppose exploits for IP devices are more what people are looking for, Hik took the method of obscuring there firmware files when they realised people where finding exploits. Edited March 20, 2020 by sixwheeledbeast typo Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 20, 2020 Share Posted March 20, 2020 30 minutes ago, GalaxyGuy said: Not much to be gained from the firmware files unless the design is secured by obscurity. Oh, wait... Seriously though, it would be pretty hard to keep these things out of the public domain these days. The touch screen displays are a bit of an expensive gimmick anyway. And why would you want to look at CCTV cameras on an alarm keypad in a hallway Etc. when you can do the same on your phone. Someone on one of the Facebook forums posted a pic of a new Honeywell commercial security range. I cannot remember the name, but it looked quite different to any of the Galaxy products of yesteryear. Doubt you get hkc firmware 9 minutes ago, sixwheeledbeast said: Just find it unusual, a lot of manufacturers try to distribute there firmware on a need to know basis, to make it harder to access. They are maybe concerned that someone could RE it and find some exploit, I am not saying it's a good or bad thing just unusual. I suppose exploits for IP devices are more what people are looking for, Hik took the method of obscuring there firmware files when they realised people where finding exploits. Texe firmware all on download public? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted March 20, 2020 Share Posted March 20, 2020 Nope. It's probably not hard to access but it's not "public" Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 20, 2020 Share Posted March 20, 2020 1 hour ago, sixwheeledbeast said: Nope. It's probably not hard to access but it's not "public" Hkc is all through licenced software Don't think you can do it with files , or atleast installers can't Jw? Quote Link to comment Share on other sites More sharing options...
