newtoalarms Posted December 4, 2019 Share Posted December 4, 2019 a few years back my brother installed a Risco lightsys system for me , it all worked fine no problems. He didn't have time to install the IP module so a while back I tried to install it but it wouldn't work (probably some setting or other) so i just removed it from the main board. I then did a factory reset from the panel (don't ask me why it seemed like a good idea at the time) ever since then I have had the same issue where I cannot get into the start menu to do anything with the panel (see images) all i see are stars. Now these normally appear for a split second but it goes into the set up menu , now its just stuck there , i posted this on another forum but despite all the great help nothing seemed to work. I have removed all other wires and just wired up a single keypad and i have tried every dip switch combo to try to pick up the keypad address but to no success. The only other symptom I notice is that when i power up the system the LED1 (status) light goes green then it just blinks slightly but never stays solid green. I appreciate any help or pointers I can get . Quote Link to comment Share on other sites More sharing options...
aissecur Posted December 4, 2019 Share Posted December 4, 2019 looks like it is asking you to maybe install (address) the keypad (not done much on this panel but the CPX / 595 & 600 there is an option to address them) Quote Link to comment Share on other sites More sharing options...
al-yeti Posted December 4, 2019 Share Posted December 4, 2019 7 hours ago, aissecur said: looks like it is asking you to maybe install (address) the keypad (not done much on this panel but the CPX / 595 & 600 there is an option to address them) They discontinued this keypad? Probably default ed keypad not the panel? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted December 4, 2019 Share Posted December 4, 2019 (edited) 16 hours ago, newtoalarms said: "Oh my god, it's full of stars...." Edited December 4, 2019 by datadiffusion Edited by HAL Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
MrHappy Posted December 4, 2019 Share Posted December 4, 2019 For a modest fee 17 hours ago, newtoalarms said: I appreciate any help or pointers I can get . power it down & buy a dog, should the dog bite you, it will still be less painful than working with that alarm.... 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
