Andy cb Posted November 12, 2019 Share Posted November 12, 2019 Hi guys looking for some advice I have a scantronic 9651 alarm with one main keypad, 5 pir detectors and smoke detectors ive had it service yearly in the 10 years I’ve had it but recently had a lot of work in the house done plastering and decorating and my now the keypad just lights up no sound and no message on it just a blank screen and I’m looking to switch the pir to pet tolerant I dint have the engineer code for the alarm so I’m guessing first thing to do would be reset the default codes then fit the new keypad and then the detectors anything I should expect or know about going from other bits on the forum each job seams fairly strait forward only thing worrying me I’d the keypad not working before the reset Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 You're right a blank keypad is not nessacarily going to be a faulty keypad. With no way of shutting the alarm up if you make a wrong move, I am not sure that I would be wanting to DIY that. 1 Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 The keypad worked just fine up till about a week ago it used to tell me it had a tamper as it had been removed from the wall to allow for the plastering I was looking to upgrade it as the casing is old and cracked and the newer keypads are smaller Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 7 minutes ago, Logan said: If you rip it out can i have it I don’t think I’ll be ripping it out just getting someone in Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 13 minutes ago, PeterJames said: You're right a blank keypad is not nessacarily going to be a faulty keypad. With no way of shutting the alarm up if you make a wrong move, I am not sure that I would be wanting to DIY that. I would get the engineer that normally serviced it but I can’t get hold of him anymore and none of my local company company’s will touch it without wanting silly money Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 9 minutes ago, Andy cb said: I would get the engineer that normally serviced it but I can’t get hold of him anymore and none of my local company company’s will touch it without wanting silly money How much is silly money? Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 1 minute ago, Logan said: May i reccomend if you decide to replace the PIRs yourself you pull the fuse out the panel and disconnect the battery. Cheers I was planning on doing it when the system was completely powered down anyway Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 2 minutes ago, Logan said: May i reccomend if you decide to replace the PIRs yourself you pull the fuse out the panel and disconnect the battery. I wouldnt do that without a working keypad Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 1 minute ago, PeterJames said: How much is silly money? 500 just to come take a look 1 Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 Just now, Andy cb said: 500 just to come take a look They must be busy round your way Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 1 minute ago, PeterJames said: They must be busy round your way So you can see why I’d like to diy it myself am i right in thinking That if I default reset with the old pad I place still then replace keypad with new one I shouldn’t run into any problems swapping the pir’s after system is all set just with new keypad Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 2 minutes ago, Andy cb said: Cheers I was planning on doing it when the system was completely powered down anyway The external sounder should start sounding on its own battery if you fully down power the panel. I say should that is what it is supposed to do. So You really need to start at the external sounder, go outside and disconnect that first, otherwise you will upset your neighbors Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 1 minute ago, PeterJames said: The external sounder should start sounding on its own battery if you fully down power the panel. I say should that is what it is supposed to do. So You really need to start at the external sounder, go outside and disconnect that first, otherwise you will upset your neighbors Ok can I disconnect that before I power down or after Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 1 minute ago, Logan said: Newer scantronic keypads wont work. You can only 9651 keypads on a 9651 I have a 9930 pad on there now from what I understand the 9943 works well and comes highly recommended for the 9651 panel Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 1 minute ago, Andy cb said: Ok can I disconnect that before I power down or after Before otherwise it will sound as soon as you power down. It will sound when you try to disconnect it but not for so long Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 1 minute ago, PeterJames said: Before otherwise it will sound as soon as you power down. It will sound when you try to disconnect it but not for so long Ok great Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 12, 2019 Share Posted November 12, 2019 Considering the mix up just with just your speaker, I would think twice about DIY. Unless your willing to take the risk of many hours/weeks learning on the job and no guarantee of a working alarm at the end of it. Words of caution if you do DIY:- External bell strobe unit has very high voltage, this and having to disconnect a sounding box on the wall up a ladder is not the most pleasant experience when you have no idea what you are doing. Be careful. Obviously the control box has mains voltage in best to isolate if your not good with electrics. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 1 minute ago, Andy cb said: I have a 9930 pad on there now from what I understand the 9943 works well and comes highly recommended for the 9651 panel II believe you are correct, I am not that familiar with Scanny anymore but I am sure someone posted here that the newer rkp's are compatible Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 So just to get this right 1 disconnect external sounder battery backup 2 default reset panel to reset engineer code 3 wire in new keypad 4 check system all working normal having reconnected external sounder 5 power back down and external sounder and swap pir’s 2 minutes ago, PeterJames said: II believe you are correct, I am not that familiar with Scanny anymore but I am sure someone posted here that the newer rkp's are compatible From what I’ve read on security warehouse it should work fine and I’ve read it on other forum’s Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 1 minute ago, Logan said: When you open the the panel disconnect what i put a red arrow pointing at NO!!!! diss the mains at the spur before opening the panel 1 Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 (edited) 6 minutes ago, PeterJames said: NO!!!! diss the mains at the spur before opening the panel Yeah or the panel/lid tamper kicks in Edited November 12, 2019 by Andy cb Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 Just now, Andy cb said: Yeah or the panel tamper kicks in No the tamper has nothing to do with it, mains electricity is dangerous Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 12, 2019 Share Posted November 12, 2019 31 minutes ago, Andy cb said: 500 just to come take a look Blag 1 Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 12, 2019 Share Posted November 12, 2019 Just now, Logan said: Well yes. However i am a competent engineer so i know what to touch and what not to touch. Still the best idea to pull the fuse out the FCU Are you? I would always recommend that the mains is isolated before the panel is opened as I would expect any competent engineer to recommend there are live terminals on the transformer and the psu Quote Link to comment Share on other sites More sharing options...
Andy cb Posted November 12, 2019 Author Share Posted November 12, 2019 15 minutes ago, sixwheeledbeast said: Considering the mix up just with just your speaker, I would think twice about DIY. Unless your willing to take the risk of many hours/weeks learning on the job and no guarantee of a working alarm at the end of it. Words of caution if you do DIY:- External bell strobe unit has very high voltage, this and having to disconnect a sounding box on the wall up a ladder is not the most pleasant experience when you have no idea what you are doing. Be careful. Obviously the control box has mains voltage in best to isolate if your not good with electrics. Thanks sixwheeledbeast but having just rewired most of my house and had it NIC inspected with no problems I am happy to take this my speaker issue earlier was from on my looking at the product from a picture and being of the belief that I had and internal sounder as well as an external one having followers yours and others advice that part of the system has been reinstated and working great Quote Link to comment Share on other sites More sharing options...
