Logan
Euro meridian keypad not working
The euro meridian system i have installed has a problem. One of the keypads (address set to 01) stopped accepting pincodes or prox tags. But the display works fine. Shows all information that it normally would.   The other keypad says "device fail 201"  as its a keypad addressed to 1.    I try the keypad on another panel and has the same problem
Share this post
Link to post
Share on other sites
I'm fairly certain the address at the first keypad should be 00 not 01.
(This may be the reason why you are getting device fail) - I may be wrong but worth a shot
Edited by aissecur
Share this post
Link to post
 There are two keypads one is the master keypad addressed 00.  And there is the additional keypad addressed 01
Share this post
Link to post
or power down remove one of the keypads (address the connected one as 00) and power back up to see if it works (try this with both different keypads in an attempt to rule out a faulty keypad)
Edited by aissecur
Share this post
Link to post
2 hours ago, james.wilson said:
As above you have confirmed the keypad address of the 2nd keypad if both addressed as 00 it would do this
They are addressed right. Just one day ot started giving a message saying "Device Fail 201" the display works fine  it even says "Device Fail 201"  however no codes or tags are accepted and gives a long error beeb.  Tryed to reboot the system. Keypad still doesn't work correctly
Share this post
Link to post
Share this post
Link to post
5 hours ago, james.wilson said:
I'd try addressing as 02 and disabling 01 in assign keypads
Still no luck. I even tryed on a different panel and it still didn't work
Share this post
Link to post
Do you know a good place to get one of these keypads. I just want to get a used one but couldn't find one on the internet as i dont want a new one as it costs to much i cant afford it
Share this post
Link to post
1 hour ago, james.wilson said:
no they are long obsolete I would think any companies that have them will keep hold of them for repair stock
I saw a euro 12 with the keypad on Security Warehouse https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/castle-care-tech-euro12-control-panel-p-1720.html
I cant afford the new style
https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/castle-care-tech-contempory-lcd-keypad-with-built-in-prox-p-1615.html
The one that failed is the same but mine says "banham" instead of "tag"
Share this post
Link to post
3 minutes ago, al-yeti said:
But i dont have a ebay account. I might have to become DataDiffusion
Share this post
Link to post
Thought your mum can bid
Share this post
Link to post
Im buying it. Hopefully i win it
Share this post
Link to post
a refurbished eur 21 brick keypad is £41+vat....
have you default your keypad ?
is the correct no. of keypad programmed into the panel ?
Mr:)
Share this post
Link to post
Yes. Still cant afford the £41 replacement. I probably go using al-yetis way.
Also your website doesn't work
Share this post
Link to post
Lol
  • Upvote 1
Share this post
Link to post
Logan, have you tried it with just one keypad at a time? (address that keypad as 00)
It seems strange both keypads are not working (I know it can happen)
Have you fully defaulted the panel?
Share this post
Link to post
The keypad addressed 00 works fine the keypad addressed 01 doesn't work
Share this post
Link to post
32 minutes ago, james.wilson said:
Have you tried reprogramming the keypad to 2 and the same in the panel??
Still nothing    i currently have it unregistered from the system  to remove the fault.  but still have it powered (has a blank screen)
Do you know where to get a castle caretech engineer keypad?
Edited by Logan
Share this post
Link to post
    No registered users viewing this page.
