More SD1+ Speech dialler problems
Ans
Frankly I would upgrade to an i-On 40H from Eaton (new name for Scantronic / Cooper), it'll be familiar to you and you can keep everything else other than the keypad, that way you'll get the free cloud app and forget this old fashioned dialler tat ;)
Edited by datadiffusion
1 minute ago, datadiffusion said:
Frankly I would upgrade to an i-On 40H, it'll be familiar to you and you can keep everything else other than the keypad, that way you'll get the free cloud app and forget this old fashioned dialler tat ;)
I never rated the sd1 etc allot of failures out there
The issue with diallers is they often take a hit when the phone line has a surge.
You can normally tell an SD1 is faulty when it misbehaves or looses it's memory while you program it.
I wouldn't say the SD1 has a higher failure rate to any others I have seen.
It does sound more like a line issue or the acknowledgment type is programmed wrong.
3 hours ago, Ans said:
In my sd1+ there is tirig input mention
A B C D/abort
in this slot which letter I want connect in my alarm panel .i want use resister or not
I give connection from my alarm panel ( bell out put ) to SD1+ letter C asper manual C is using for alarm
but I not respond in this device
Is this a separate issue to not being able to ack the call?
