Veritas R8 problem
Hi
I have veritas r8 alarm system zone 1 door contact as entry/exit but i need to have zone 2 the same as when setting alarm going to bed i have to pass hall pir to get to my bedroom so when i get up and go passed zone 2 the alarm goes off imediately
how can i make zone 2 like the front door with a delayed alrm so i can turn the system off before the alrm goes off
please can someone help
i have tried to follow steps from the manual with no direct outcome
regards
roy
You need to program (and use) part set for nights then, this does not mean you cannot have full coverage, just that the behaviour of some zones is different at night, e.g. not an instant alarm but a delayed one.
Edited by datadiffusion
You can program systems to do whatever you need but the best solution is using the part set.
The correct term for Texecom panels is "Guard Access" or "Inhibited Entry".
You will need to reprogram the Part set function for Zone 2 to be Entry/Exit and the full set for Zone 2 to be Inhibited Entry
OK so please can you talk me through the setting up proceedure for that  i find it difficult t follow the manual as it states
firt put in code  ok
then press 1 2
then press 2 to make it entry/exit but nothing changes
have i wired it up correctly
the wire in the pir are from left to righ
black red  blue yellow  green white
the alarm box in the loft is
black red for power yes
blue yellow foor the zone 2
white green joined in sequence with all oth pir's
do i need to change anything?
