sixwheeledbeast Posted August 18, 2019 Share Posted August 18, 2019 It's been a good while since I have done multi panel on Advanced, it is possible. Every site is going to be different tho it's not just a switch this on or off. When you call them make sure you explain the site layout, zones and what the system needs to do. It's a life system so make sure everything including all cause and effect is right when commissioning or it's your head on the block. Quote Link to comment Share on other sites More sharing options...
Prodigious Posted August 18, 2019 Author Share Posted August 18, 2019 Yes 100% I’m familiar with cause and effect programming which I’m comfortable with now after many years. as yourself I’ve not done many multi panel and the ones I’ve done wanted the other panels to go into fire Also, but this new project just wants a warning alert to come up on the other building panels, these buildings are 50meters apart and not attached in anyway Quote Thrones Link to comment Share on other sites More sharing options...
