norman Posted July 18, 2019 Share Posted July 18, 2019 Yup, had one in my house for years (Modern Alarms variant) never missed a beat. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
PeterJames Posted July 18, 2019 Share Posted July 18, 2019 I always found it weird that the 9800 was the LED older panel and the 9600 was the lcd newer panel but the 9100 was the oldest panel. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 18, 2019 Share Posted July 18, 2019 1 hour ago, PeterJames said: I always found it weird that the 9800 was the LED older panel and the 9600 was the lcd newer panel but the 9100 was the oldest panel. Isn't scantronics still weird? Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted July 19, 2019 Author Share Posted July 19, 2019 9 hours ago, al-yeti said: Isn't scantronics still weird? Scantronic is dead, all hail Eaton 10 hours ago, PeterJames said: I always found it weird that the 9800 was the LED older panel and the 9600 was the lcd newer panel but the 9100 was the oldest panel. I wonder if the whole affordability of LCDs caught them a little by surprise but someone in marketing didn't like the sound of 9900! I had what I think was a prototype Mosaic RKP once (in a 9610 type keypad enclosure) which I think had the part number 91000 or something, it looked odd and obviously got totally changed for the main production. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
al-yeti Posted July 19, 2019 Share Posted July 19, 2019 1 hour ago, datadiffusion said: Scantronic is dead, all hail Eaton I wonder if the whole affordability of LCDs caught them a little by surprise but someone in marketing didn't like the sound of 9900! I had what I think was a prototype Mosaic RKP once (in a 9610 type keypad enclosure) which I think had the part number 91000 or something, it looked odd and obviously got totally changed for the main production. Well they took a bit longer than Bosch did to da invuess Quote Link to comment Share on other sites More sharing options...
MrHappy Posted July 19, 2019 Share Posted July 19, 2019 (edited) 13 hours ago, Logan said: Want some memories. How about the scantronic 9600 I see a sticker off a redcare on it.... 9600 /9610 When part set, sometimes some one moving in zone that was omitted could trigger the alarm when in entry. They also kept making the e/e tone from the rkp, when you'd turned it off & you'd have to walk test to make it stop... The 1060,1062, 1064 ? sensor in the pic also caused problems something on the pcb acting like an Ariel ?, we replaced a lot with 1080 twintec the product was something to do with arrowhead ? At the same time we was fitting 9452's / 9453's which didn't work proper with a keypad & needed a capacitor adding to make them stable ? I think we then went to 700l's & Apollo solo's & had less issues ? Edited July 19, 2019 by MrHappy Quote Mr Veritas God Link to comment Share on other sites More sharing options...
datadiffusion Posted July 19, 2019 Author Share Posted July 19, 2019 30 minutes ago, MrHappy said: 9600 /9610 When part set, sometimes some one moving in zone that was omitted could trigger the alarm when in entry. They also kept making the e/e tone from the rkp, when you'd turned it off & you'd have to walk test to make it stop... Did that continue even with the 9610? Even the hardware on the later version seems quite different. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
