Premiere Elite 24 external sounders off during part set at night.
Hi There
Can anyone tell me how to turn off the external sounders (sab) On part set for night time use
, I can’t seem to find it in the set up instructions, had this option on our previous Veritas 8 system.
My new system is the Texecom Elite 24
thanks
Bill
  • Replies 21
That's not an out of the box option on a Premier. It's not something that you would normally do.
You would need to use custom outputs to do custom things. Something like have a stage for Bell SAB and a Inverted stage for Part armed.
Alternatively if it's concern for waking the neighbours in the night you can set the part set bell delay timer to whatever time you feel.
Toggle switch like that is far from ideal.
If it fails, you forget to switch it or it is found in a break in, your alarm is useless.
The design behind a self activating bell is that everything is contained within it and only controlled by the panel so they are harder to defeat in a break in.
I would suggest a small part set bell delay is the most appropriate.
2 hours ago, james.wilson said:
Could you use an intruder output with a 15 min confirm timer and then disable comms in part set. Afraid I don't know the panel at all
Why disable coms?
