jezthomp Posted June 4, 2019 Share Posted June 4, 2019 The other day we had a couple of quick power cuts in close to each other, annoying as they were only a couple of seconds each. We were out and the alarm was on, when arriving back home we found the alarm was going off. The panel had power to it as the keypad numbers were lit up but there were not lights below, the TA, PA, Day & Power ones they are not showing at all. I had no idea what to do and just put the code in various times and it eventually went off ( i dont know how many times or if this is even the correct thing to do ). The external strobe light is still flashing now but no alarm annoying everyone at least! I've done some basic research that means it could be the battery that needs replacing in the CPU box thats in the loft? Its the older one that doesn't have a keypad on that particular box. I should turn the power off and remove the cover and look at replacing the battery within it. When it says to turn the power off, is this just literally turning off the whole power to the house via the fuse/junction box in the garage, or can i get away with just removing the fuse thats along side the box in the loft? I replaced the batter in our old house alarm so am keen to give this a go but would like to do it without the alarm going off, i assume if i turn the power off to the whole house (or just remove the fuse) the alarm shouldn't sound? Also am i looking at replacing it with a battery like this on... Many thanks for any thoughts or opinions Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 Hi: Yes you can remove the fuse from the spur at the side of the controls. Unfortunately this will set your alarm off, as it did when the mains failed. Do you have the Engineer reset code or just the User code ?. When you remove the box lid to change the battery, this should cause a tamper fault. On some alarms this can only be reset with the Engineer code. Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
jezthomp Posted June 4, 2019 Author Share Posted June 4, 2019 Just now, Specialist said: Hi: Yes you can remove the fuse from the spur at the side of the controls. Unfortunately this will set your alarm off, as it did when the mains failed. Do you have the Engineer reset code or just the User code ?. When you remove the box lid to change the battery, this should cause a tamper fault. On some alarms this can only be reset with the Engineer code. Hi, thanks for your reply. I have the original instructions which mentions about an engineer code, or is this specific to the engineer who originally installed it? I don't think there is a key panel within the box from some initial interest research. Will removing the fuse act as turning power off to enable me to open the box without any danger? Surely if i just turn the power off to the house the alarm will go off? Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 (edited) Hi: Do you mean the Installer or user manuals ? If you take the fuse out at the side of the panel or turn the main house switch off ( Best option) the alarm should sound outside, that's what it's designed to do. Your panel can be set to either user or engineer reset on tamper, if engineer reset is enabled then the Installer will usually have changed the engineer code to one of his own. If he has then entering your code once you change the battery and refitted the panel lid, will silence the alarm but won't let you set it until the engineer code is entered. A tamper light or message will show on the keypad until reset. Edited June 4, 2019 by Specialist Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
jezthomp Posted June 4, 2019 Author Share Posted June 4, 2019 Just now, Specialist said: Hi: Do you mean the Installer or user manuals ? If you take the fuse out at the side of the panel or turn the main house switch off ( Best option) the alarm should go off outside, that's what it's designed to do. Your panel can be set to either user or engineer reset on tamper, if engineer reset is enabled then the Installer will usually have changed the engineer code to one of his own. If he has then entering your code once you change the battery will silence the alarm but won't let you set it until the engineer code is entered and a tamper light or message will show on the keypad. Just the manuals we have, so assume have no idea if an engineer code has been changed. The alarm did silence after the power cut with me putting my code in a few times, so could that be assumed there isn't an engineer code as i've changed that since we moved into the house. Can i ask how it works even though i've turned the power off to the house, what's powering it? Especially if it needs a new batter? Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 (edited) Hi: The power going off just set the alarm off, it never caused a tamper condition so your code would reset the alarm. There's a battery inside your external sounder Which would power the siren in the event of say a cable being cut or the system going into alarm as yours did, in your case the power coming back on would have taken over powering the siren again and kept it running. Edited June 4, 2019 by Specialist Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 Sorry, I missed answering part of your original question. Yes the battery you show should be fine as a replacement in your panel. One other thing: Make sure you have a good torch when going to replace the battery, you'd be surprised how many people forget this. Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
jezthomp Posted June 4, 2019 Author Share Posted June 4, 2019 22 minutes ago, Specialist said: Hi: The power going off just set the alarm off, it never caused a tamper condition so your code would reset the alarm. There's a battery inside your external sounder Which would power the siren in the event of say a cable being cut or the system going into alarm as yours did, in your case the power coming back on would have taken over powering the siren again and kept it running. Ah ok, that makes sense. So I turn power off, alarm goes off I put my code in and nothing happens, what would i do then? Will turning the power back on stop the alarm? Also how will the panel have power if the house power is off and the battery is the problem? Thank you for you help Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 (edited) The panel won't have power. The external sounder will, via it's own battery. It's the loss of power from the panel to the sounder that causes it to go into alarm. Until you reconnect the battery or apply mains power to the panel, you won't be able to silence the alarm. When all power is removed from the panel the sounder should sound for no more than 15 to 20 minutes, your best option would be to have someone by the keypad to enter the code and silence the alarm as soon as you reconnect the battery. Edited June 4, 2019 by Specialist Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
al-yeti Posted June 4, 2019 Share Posted June 4, 2019 (edited) 32 minutes ago, Specialist said: The panel won't have power. The external sounder will, via it's own battery. It's the loss of power from the panel to the sounder that causes it to go into alarm. Until you reconnect the battery or apply mains power to the panel, you won't be able to silence the alarm. When all power is removed from the panel the sounder should sound for no more than 15 to 20 minutes, your best option would be to have someone by the keypad to enter the code and silence the alarm as soon as you reconnect the battery. Some old bells ring like lunatics, as if they getting power from the grid...... Edited June 4, 2019 by al-yeti Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 (edited) That goes for old alarm engineers too mate (Not that I'm saying Your old, you understand) Edited June 4, 2019 by Specialist 1 Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
jezthomp Posted June 4, 2019 Author Share Posted June 4, 2019 (edited) 42 minutes ago, Specialist said: The panel won't have power. The external sounder will, via it's own battery. It's the loss of power from the panel to the sounder that causes it to go into alarm. Until you reconnect the battery or apply mains power to the panel, you won't be able to silence the alarm. When all power is removed from the panel the sounder should sound for no more than 15 to 20 minutes, your best option would be to have someone by the keypad to enter the code and silence the alarm as soon as you reconnect the battery. Currently the alarm isn't going off, i just want to get the lights back on the panel and back to the normal working condition. I'm just trying to determine how to deal with the various scenarios. Worse case being i turn off power the alarm goes on and i just cannot turn it off again. Plan is to turn power off, open CPU, put my code in the panel and hope the alarm goes off, i can then see the battery i need and replace. I'm just not 100% on what to do if my code doesn't work. Edited June 4, 2019 by jezthomp Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 4, 2019 Share Posted June 4, 2019 9 minutes ago, Specialist said: That goes for old alarm engineers too mate (Not that I'm saying Your old, you understand) Hardcore lol 2 minutes ago, jezthomp said: Currently the alarm isn't going off, i just want to get the lights back on the panel and back to the normal working condition. I'm just trying to determine how to deal with the various scenarios. Worse case being i turn off power the alarm goes on and i just cannot turn it off again. Plan is to turn power off, open CPU, put my code in the panel and hope the alarm goes off, i can then see the battery i need and replace. I'm just not 100% on what to do if my code doesn't work. Depends how much you value your security , I would scrap it and get new system in , although many wait for there CAMBELT to snap aswell Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 (edited) Hi: If you replace the battery and get a tamper that your code won't reset, you have a few options. 1) Call the original installer to reset for you. 2) Call another Installer to crash and reprogramme the alarm for you, while replacing the battery. Please don't ask how to crash the panel as it's against our rules to give that information. 3) Do as al-yeti suggests and have a new panel installed. Edited June 4, 2019 by Specialist Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
jezthomp Posted June 4, 2019 Author Share Posted June 4, 2019 2 minutes ago, Specialist said: Hi: If you replace the battery and get a tamper that your code won't reset, you have a few options. 1) Call the original installer to reset for you. 2) Call another Installer to crash and reset the alarm for you, please don't ask how to crash the panel as it's against our rules to give that information. We're having the company that fitted(i think)/serviced it come on Thursday. They apparently serviced it in February, but god knows if they replaced the battery or not! Would happily have a new alarm fitted but don't fancy the whole house being re-wired, the current wiring is fine its just obviously an older system. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted June 4, 2019 Share Posted June 4, 2019 it shouldn't need rewiring assuming it was installed correctly. A company should test the battery at service and replace at 3-5 years anyway. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 4, 2019 Share Posted June 4, 2019 Alarm systems need regular maintenance to avoid issues like this, SLA batteries have an expected life of 4 years for good quality ones. I would suggest you have the system serviced by the installer. Alternatively if you are feeling competent to DIY, it would be sensible to check the voltage and charging rate with a multimeter, when you replace the battery otherwise you will be back up there again next power cut. It is up to you if you want to isolate the mains before opening the cover, most engineers would not but they would also be unlikely to poke there fingers near the mains terminals. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted June 4, 2019 Share Posted June 4, 2019 It may be too late if you have not replaced the battery when it was due you may well find that the charging circuit is knackered anyway Quote Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 12 minutes ago, jezthomp said: Currently the alarm isn't going off, i just want to get the lights back on the panel and back to the normal working condition. I'm just trying to determine how to deal with the various scenarios. Worse case being i turn off power the alarm goes on and i just cannot turn it off again. This very rarely, if ever happens. Plan is to turn power off, open CPU, put my code in the panel and hope the alarm goes off, i can then see the battery i need and replace. The battery you need to replace is the one inside the panel, with the one you pictured. Absolutely no need to open the panel to look at it first. If your unsure of what to do, you may be better off calling in a local Installer. Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 4, 2019 Share Posted June 4, 2019 If it's well looked after it's unlikely to need replacing. Either way the wires could be reused if in good condition. . Quote Link to comment Share on other sites More sharing options...
james.wilson Posted June 4, 2019 Share Posted June 4, 2019 4 minutes ago, Specialist said: The battery you need to replace is the one inside the panel, with the one you pictured. Absolutely no need to open the panel to look at it first. If your unsure of what to do, you may be better off calling in a local Installer. assuming a 2.1 is big enough. OP the battery is sized depending on panel load Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
jezthomp Posted June 4, 2019 Author Share Posted June 4, 2019 I'm all for getting a new system just have no idea how much these things cost, the Accenta 7 seems fairly old but apart from this its been fine. We have an engineer coming Thursday so will see what he says, just seems odd they serviced it in Feb and then a power cut has caused this issue. Also odd that the keypanel buttons are illuminated but none of the TA, PA, Day & Power ones below it are and also how me just putting the code in lots of times worked! Thank you all for your options Quote Link to comment Share on other sites More sharing options...
james.wilson Posted June 4, 2019 Share Posted June 4, 2019 just to add to the above. lets hope it 'works' if its needed etc Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 12 minutes ago, james.wilson said: assuming a 2.1 is big enough. OP the battery is sized depending on panel load Don't think that panel will take more than a 2.1. Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
Specialist Posted June 4, 2019 Share Posted June 4, 2019 10 minutes ago, jezthomp said: I'm all for getting a new system just have no idea how much these things cost, the Accenta 7 seems fairly old but apart from this its been fine. We have an engineer coming Thursday so will see what he says, just seems odd they serviced it in Feb and then a power cut has caused this issue. Also odd that the keypanel buttons are illuminated but none of the TA, PA, Day & Power ones below it are and also how me just putting the code in lots of times worked! Thank you all for your options The TA (Tamper) & PA (Personal attack) lights would only light in the event one of these circuits was activated. The day light would normally be on once the panel is fully reset and in normal day mode. Quote Customers Love us, Intruders Hate us. Link to comment Share on other sites More sharing options...
