Sirtoddius Posted May 8, 2019 Author Share Posted May 8, 2019 55 minutes ago, sixwheeledbeast said: I think it's right we should question the integrity of equipment installed. Totally agree. Especially when it is potentially to do with national security. I will have to try and find the article I read that said about a way they can dial into a networked Dvr/nvr without passwords etc. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 8, 2019 Share Posted May 8, 2019 32 minutes ago, sixwheeledbeast said: Ah, you maybe right. Not sure if it's all of the range tho. Only the banned manufacturers list (Hik, ZTE, Huawei plus a few others), not everything Chinese. From the US Security Camera Compliance with the 2019 National Defense Authorization Act (NDAA) On Aug 1, 2018, the US government passed a resolution, effective Aug 1, 2019, to prevent the federal government, and anyone else who is involved with national security, from making purchases of telecommunications and surveillance cameras originally manufactured in 5 specific factories in China. The ban affects some or all Honeywell, Hikvision, Dahua, Lorex, Swann, LTS, Annke, Alibi, Laview, WBox, Interlogix, Flir, Bosch, ICRealtime, QSee, Panasonic, ADT, Indigo Vision, and many more security products. Your not going to avoid the potential exploits of a blacklisted supplier by avoiding a certain brand , its way too complex Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted May 8, 2019 Share Posted May 8, 2019 (edited) 6 minutes ago, MrHappy said: From the US Your not going to avoid the potential exploits of a blacklisted supplier by avoiding a certain brand , its way too complex The way they see it , it's damage limitation nothing else Any hik rebadged still ends up using hikconnect or an app connected to them So if your contract says don't use it ,why would you risk using hik with another label on it, as eventually it will lead to there software and updates and you won't get paid I now opted to use what genie wish range have (only different supplier with no badge and 1/3 of the cost ) All made by TVT China ....... Edited May 8, 2019 by al-yeti Grammar is bad as it is all this china talk making me type even weirder 1 Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted May 8, 2019 Share Posted May 8, 2019 The installer would be liable if found to be on the banned list, rebrand or not. 1 Quote Link to comment Share on other sites More sharing options...
MrHappy Posted May 8, 2019 Share Posted May 8, 2019 there need to be whitelist 24 minutes ago, al-yeti said: Any hik rebadged still ends up using hikconnect or an app connected to them So if your contract says don't use it ,why would you risk using hik with another label on it, as eventually it will lead to there software and updates and you won't get paid I'd assume most don't know what kit is under what badge & when the products are revised there's a chance it could be sourced from OEM Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Alpat Systems Posted May 9, 2019 Share Posted May 9, 2019 On 07/05/2019 at 22:13, Sirtoddius said: E I need to find a hik alternative as most of our work is in NHS/ government buildings and your not allowed to use hikvision in those type of buildings. That’s government law. Cheers We use https://www.videcon.co.uk/ as the alternative to HIK On 07/05/2019 at 22:50, MrHappy said: what the point ? If they don't want hik they must have spec of want they do want ? The majority of Councils / Government customers run there CCTV/Security projects under NEC3 contracts and CDM rules. They expect the security experts they have chosen, who would have been selected to go onto there procurement framework to be principal Designer/designer. Its extremely rare you will come across a government institute who would become design responsible. 2 Quote Link to comment Share on other sites More sharing options...
Sirtoddius Posted May 12, 2019 Author Share Posted May 12, 2019 Thanks to those to helped. It’s a minefield but at the same time understandable from the governments point of view. It’s obviously been researched by them. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 12, 2019 Share Posted May 12, 2019 21 minutes ago, Sirtoddius said: t’s obviously been researched by them. Nah. Quote Link to comment Share on other sites More sharing options...
satsuma01 Posted May 14, 2019 Share Posted May 14, 2019 On 08/05/2019 at 20:29, Sirtoddius said: Totally agree. Especially when it is potentially to do with national security. I will have to try and find the article I read that said about a way they can dial into a networked Dvr/nvr without passwords etc. Did you manage to find the article about them logging into the systems Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment Share on other sites More sharing options...
emsgeorge Posted May 28, 2019 Share Posted May 28, 2019 We've been advised by the 'expert' that a local council brought in, that we could use hik, as long as its only cameras, and not dvrs, and only if the system was coax based, rather than IP. The basis of the conversation being that if its not a hik dvr, and the system isn't IP, then they couldn't possibly dial into the cameras, as that would have to be via the dvr, which not being hik, couldn't happen. Although a lot of the larger buildings we look after for said council are all IP, as the original design was all done via cat5 and switches on each floor. Quote Link to comment Share on other sites More sharing options...
