Tonybeemer
Premier Elite 64 W
Hi every one, I've just purchased a new Texecom Ricochet 64 Way. Set up the system 3 PIR and 1 door contact no problem apart from I realised that when setting up the config it turns of the zones on the hard wired panel so I re instated them in the config/programme menu as I wanted to add two additional hard wired PIR  and looped out the other two. But unless these zones are set as not used I get tamper showing? Any Ideas please? Thanks.
Share this post
Link to post
Share on other sites
High James. Normally the Veritas panels come with a little bag of resistor but on this occasion not. So I just linked out with cable is this my problem?
Thanks.
Share this post
Link to post
Hi James, possible. Just a bit strange as I've seen someone on YouTube having the same problem but for them it was  a easy fix as they were using all wireless PIR so just set the wired on board zones to not in use?
Thanks.
Share this post
Link to post
Welcome.
Speak to your supplier about the missing parts, they should hopefully give you replacements.
Share this post
Link to post
Where you panel?
eBay?
amazon?
Think they have returns policy if bits were missing , maybe it was used panel , although resistors are cheap and programming them out is easier
Share this post
Link to post
Register a new account
Sign in
    No registered users viewing this page.
