Galaxy 2-12 C012 honeywell security
hi;
we just installed a new intruder alarm system and the technician got into the menu of the Galaxy 2-12 C012. but now we cannot access the engineer code. is there a way how to masterr rest/factory reset the system so we will start from scratch please.
thanks
4 hours ago, will cpi said:
hi;
thanks
Perhaps give more info
Do you mean you installed it yourself or someone installed used am engineer code and then left
Why do you want to reset default system if it's just been installed?
5 hours ago, will cpi said:
hi;
thanks
If you leave the main control panel in the freezer over night it defaults back to its factory settings
Do I need to disconnect the mains first or just throw it in with the peas.???
I remember something about that, what device was it when frozen could be bypassed ?
we just installed it and it is not ready yet and the technician that is installing it might changed the engineer code by mistake or he do not remember
You need new engineer then who can reset it for you, we can't give that information here
You sure your not house bashing ? Get new engineer to do it for you
hi al-yeti; to have access to the engineer code you need the user code, we have the user code to give permission to insert the engineer code, what we do not have is the engineer code, what we need is just factory reset the system to finish programming the panel
Yes I understand that but I am saying get a new engineer to do this for you
Where is engineer
