led floodlights maximum wattage on a house
1 hour ago, sixwheeledbeast said:
All I need is a lens and a dead bat to summon Mr H...
You'd need the prat symbol, not the bat symbol...
1 hour ago, james.wilson said:
i believe there is a 150watt limit on floor lights?
there's some shite about the wattage of halogen tube
(it is /was harder to buy 500w?)
however light is measured in lumens,
its something to do with Part L
http://www.lllwww.co.uk/building_reg.html
but this may only be new builds?
reading this I assume if the fitting exceeds 45 lumens per watt there is no limit? (table 42 page 81 of attachment)
my fitting is 17000 lumens at 150 watt on the front
jpw-partl.pdf
1 hour ago, norman said:
Who would care enough to be an issue?
no one probably but thought id check for customer info too.
3 hours ago, sixwheeledbeast said:
That would only be for equipment fitted to pass building control, so new builds etc.
Your fitting would be 113 l/W anyway.
no that reg is for existing dwellings 1a is for new build as far as I can see
