Nova-Security Posted February 26, 2019 Share Posted February 26, 2019 4 hours ago, GalaxyGuy said: The Flex+ supports grade 3. Oh dear, sounds like a dimension replacement. Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
GalaxyGuy Posted February 27, 2019 Share Posted February 27, 2019 Okay, checked this out on the Flex with a RIO. So what you need to do is configure the virtual RIO in the RF portal so that it doesn't take any addresses up. Ie. No virtual RIO enabled. Then you can configure any of the 20 hardwired zones as either wireless or hardwired. The easiest way to do this is to: 1. Enter engineering mode and remove both portal and rio from the system. 2. Exit engineering mode and remove the devices from the config when prompted. 3. Set the RIO address to 2 and add back to the bus. 4. Enter eng mode and menu 72 to detect the device. 5. Add the portal and then menu 72 to detect it. Now the portal should show on its bus, but with no virtual RIO's addressed (menu 51.60.1 shows the virtual RIO - note my typo earlier when I said it was 56). If you want to do this without removing devices, you need to use 51.60.1 to diable the virtual rio, then the hard wired RIO can be enumerated onto the bus. 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 28, 2019 Share Posted February 28, 2019 34 minutes ago, GalaxyGuy said: Okay, checked this out on the Flex with a RIO. So what you need to do is configure the virtual RIO in the RF portal so that it doesn't take any addresses up. Ie. No virtual RIO enabled. Then you can configure any of the 20 hardwired zones as either wireless or hardwired. The easiest way to do this is to: 1. Enter engineering mode and remove both portal and rio from the system. 2. Exit engineering mode and remove the devices from the config when prompted. 3. Set the RIO address to 2 and add back to the bus. 4. Enter eng mode and menu 72 to detect the device. 5. Add the portal and then menu 72 to detect it. Now the portal should show on its bus, but with no virtual RIO's addressed (menu 51.60.1 shows the virtual RIO - note my typo earlier when I said it was 56). If you want to do this without removing devices, you need to use 51.60.1 to diable the virtual rio, then the hard wired RIO can be enumerated onto the bus. As simple as that ! Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 28, 2019 Share Posted February 28, 2019 top post gg Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Pilotech Posted August 1, 2019 Share Posted August 1, 2019 On 27/02/2019 at 23:45, GalaxyGuy said: Okay, checked this out on the Flex with a RIO. So what you need to do is configure the virtual RIO in the RF portal so that it doesn't take any addresses up. Ie. No virtual RIO enabled. Then you can configure any of the 20 hardwired zones as either wireless or hardwired. The easiest way to do this is to: 1. Enter engineering mode and remove both portal and rio from the system. 2. Exit engineering mode and remove the devices from the config when prompted. 3. Set the RIO address to 2 and add back to the bus. 4. Enter eng mode and menu 72 to detect the device. 5. Add the portal and then menu 72 to detect it. Now the portal should show on its bus, but with no virtual RIO's addressed (menu 51.60.1 shows the virtual RIO - note my typo earlier when I said it was 56). If you want to do this without removing devices, you need to use 51.60.1 to diable the virtual rio, then the hard wired RIO can be enumerated onto the bus. I had exactly the same issue. Thank you so much for sharing. Now I just need to work out how to use the Ethernet module to connect to the app... Quote Link to comment Share on other sites More sharing options...
satsuma01 Posted May 27, 2022 Share Posted May 27, 2022 (edited) Hi regarding the galaxy flex 20 panel setup if you do the following to put the wired Rio onto the system it works first time Address Rio as 2 Address keypad as 3 and above Make sure rf Rio in menu 56.60.1 is disabled Rf Rio will show as 102 but wont see it active Exit engineering mode to check for tampers and any additional mods Once system found new Rio give system a restart to save config and refresh the system The extra zones 1021 to 1028 will be seen and active fir new detectors to be wired/added Apologies that this thread is older but thought it was relevant to the same topic Edited May 27, 2022 by satsuma01 Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment Share on other sites More sharing options...
