esw7scottia
esw7scottia
Hi Folks.  we have resently taken over a tea rooms with 4 door sensors and 2 pir.  the control is a EUROSEC CP8L  LCD.
There is a problem with the pir in the back room going off more frequently.
this would seem to be low backup battery or faulty pir.
Can I open up the control and replace the battery and at the same time replace the pir?
I dont know if there is an internal tamper alarm, Do you?
Barry And Debs
Barry And Debs
Barry And Debs
Just try it
Worse case if you value the property you will have alarm fixed by an engineer
