Honeywell Galaxy Flex 20 Configuration.
6 minutes ago, RevolvingSteve said:
Sorry guys im still confused.... Can you draw it in crayon, as clearly that's my level!
Look at your picture
Right hand vertical board at top there is a switch , next to it is a jumper with two small pins , use the jumper to short both pins this will close the tamper
If the card was in its own box it would have a spring on the switch instead
On 19/01/2019 at 15:09, al-yeti said:
So buy an expander as you have a 20 zone panel I thought
OK, C072 RIO fitted next to the main panel.
 Couple of questions:
1) Zone wiring is different, no 12v on the Zone terminals ( 1, 0v, 2, 3, 0v, 4 etc), I presume the 12v is connected to one of the 12v outputs on the opposite side of the expansion modules?
2) I can't find a wiring diagram for connecting the RIO to the main panel - Looking at it it looks like the B & A terminals on the RIO, but not sure the other end
Why you keep the cable stripped so short? Strip back more will be easier for you to manage
Also generally yes , a&b correct , I haven't really used the flex but the Rio could be powered with  single keypad and you could take an aux 12v from panel if it has one to Rio
Few ways you can do it can't see pics that well
