galaxy bell wiring
Hi i am trying to connect a FPDELTAX3MOD Deltabell X G3 Module, (backlit, twin piezo) to a galaxy dimension 48 ( have moved jumper on bell to G2) have tried it couple of ways into rio 0 with std galaxy setting, could do with correct wiring (or bell goes of when closing bell lid), i have follow info in post below any help would be really greatfull thanks.
G3 module as I myself helped by an alarm monkey is looking for power on the trigger you need a resistor there , look at drawings / instructions again
29 minutes ago, MrHappy said:
IIRC they require pull up resistors for the bell trigger, when absent or wrong value its sounds when you close the tamper.
Oh Yeah that's what you call it
+1
