Ramanoop Posted January 14, 2019 Share Posted January 14, 2019 Do you use quad detectors as a matter of course? I’ve seen some posts here saying that all reputable installers use quad detectors. But that doesn’t seem right - Texecom for example only sells one kit with quad detectors in it. The rest have ordinary pet friendly ones. wondering whether there is really a benefit Quote Link to comment Share on other sites More sharing options...
james.wilson Posted January 14, 2019 Share Posted January 14, 2019 never use 'pet' sensors. Mostly use quads Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted January 14, 2019 Share Posted January 14, 2019 IMO quads are the better detector for domestic environments. I do use pet detectors, I have a pet myself and use the Bossch Blueline DT, never had a fa and the detectors see me when I walk around the areas that I allow my dog when the system is set. In my bedrooms I have quad detectors. We only use quads we wont use cheap detectors they are just not worth it to save £5 per detector. We use Optex RX 40 mostly (Optex only make detectors so they are good at it) or the HKC Quad if we are using ID wiring. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 15, 2019 Share Posted January 15, 2019 Use quads as a minimum here as well. Same as above Optex or Bosch Bluline on the rare occasion I have to use a pet sensor. Consider many pet sensors mask or desensitise an area this can make them slow to respond in some environments. I fit Texecom controls and I never buy kits, they package the minimum stuff up for DIYers but there is never a job they fit well on, even some of the smaller kits. I purchase specific tested products from different manufacturers for the applications they go in, otherwise you may as well buy a kit from B&Q would be easier to install too. Quote Link to comment Share on other sites More sharing options...
KWCFC Posted January 15, 2019 Share Posted January 15, 2019 The wireless Pyronix pet sensors you have to do two backflips and a cartwheel for the bloody things to detect movement. Quote Link to comment Share on other sites More sharing options...
petrolhead Posted February 1, 2019 Share Posted February 1, 2019 (edited) On 15/01/2019 at 19:10, KWCFC said: The wireless Pyronix pet sensors you have to do two backflips and a cartwheel for the bloody things to detect movement. true, but if you cut the top bar off the pet mask they are a lot more sensitive but still tolerate pets. nothong comes close to the bosch for being sensitive while still disregarding pets though. Edited February 1, 2019 by petrolhead Quote Link to comment Share on other sites More sharing options...
KWCFC Posted February 1, 2019 Share Posted February 1, 2019 9 hours ago, petrolhead said: true, but if you cut the top bar off the pet mask they are a lot more sensitive but still tolerate pets. nothong comes close to the bosch for being sensitive while still disregarding pets though. Yeah I was actually told that by Pyronix tech support when I first fitted them and struggled to walk test. A bit of a **** design if you have to do that ain't it Quote Link to comment Share on other sites More sharing options...
Amps Posted February 2, 2019 Share Posted February 2, 2019 On 15/01/2019 at 19:10, KWCFC said: The wireless Pyronix pet sensors you have to do two backflips and a cartwheel for the bloody things to detect movement. They need to be installed at 2.1 meters rather than 2.4 meters for the standard pir’s. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted February 2, 2019 Share Posted February 2, 2019 Another benefit of the Bosch is flexible mounting height even in pet setting. Quote Link to comment Share on other sites More sharing options...
whistle Posted February 2, 2019 Share Posted February 2, 2019 Only ever fit dualtec’s. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 2, 2019 Share Posted February 2, 2019 36 minutes ago, whistle said: Only ever fit dualtec’s. I did a sub job , they provided texecom dualtecs , i mainly use Honeywell dt The texe version probably ok but gave to many fa , had to change them all and all gone quiet Not to say Honeywell are better question for you dudes Do you ever find some properties just don't get on with the some pirs and DTS or simply you stick to one brand and it always works? Quote Link to comment Share on other sites More sharing options...
KWCFC Posted February 2, 2019 Share Posted February 2, 2019 9 hours ago, Amps said: They need to be installed at 2.1 meters rather than 2.4 meters for the standard pir’s. Yeah I noticed they worked better lower down but that's still no good on a domestic. They need to be near the ceiling else it looks poor in my opinion Quote Link to comment Share on other sites More sharing options...
Amps Posted February 2, 2019 Share Posted February 2, 2019 1 hour ago, KWCFC said: Yeah I noticed they worked better lower down but that's still no good on a domestic. They need to be near the ceiling else it looks poor in my opinion Yeah I agree. Far from perfect. Stupid thing is for the wireless version there is no mention of the 2.1m height Quote Link to comment Share on other sites More sharing options...
whistle Posted February 2, 2019 Share Posted February 2, 2019 Guardall DT15+ fitted well over a 1000 of them with very few issues at all. Quote Link to comment Share on other sites More sharing options...
