Galaxy 48 external bell/siren/box connections
dave36
15 hours ago, dave36 said:
That's great many thanks I will give this a go - where does the white tamper wire go - into the 0v ? with the black
You've not shown the white wire in your image, so I cannot tell you.
Your picture doesn't show where white is connected in bell box end
Sorry, the white wire goes to the other tamper connection. However with many thanks to you all the bell and tamper are now working fine, the strobe doesn't work but its not too important.
I can't see a reason as to why the strobe isn't working unless the wire is in the wrong place or it is set wrong under outputs.
Probably outputs
I don't get it why is white going to the other tamper terminal? And where does it go in the panel
1 hour ago, dave36 said:
the white wire goes to a terminal just above the blue wire in the photo and both are marked T.
on the panel I've put it in the far right terminal with the 0v wire.
I still don't get it
The white wire goes to a tamper terminal
Then the other terminal should be like led to zero volts unless your using more than one bell
If both are marked T, then either take the white back to 0v in the panel too, or just remove the white wire and place a wire link from that 'T' connection in the siren to the black 0v in the siren.
  • Upvote 1
