Galaxy 48 external bell/siren/box connections
dave36
Hi
Hope that someone can help - I've just moved into different premises and there is a galaxy 48 on the wall, but all the cables had been disconnected. Well I've figured out the keypads and the detectors but there is a six core cable going to the bell box and I am having trouble with it to say the least!
Obviously (I think) that red is +VE and black is 0v,  blue and white seem to be tamper which leaves green and yellow. But when I connect them the siren either remains silent or goes off constantly.
So am I connecting to the correct place? the RIO outputs, or do I need to fit resistors?
Apologies if this is a stupid question. all my previous alarms were far less complicated :-)
Hi
Green wire to str, yellow to bell, red and black to + and - blue and white to T
under that there are some jumpers pos/neg, sab/sbc batt sel int/ext
although the bell doesn't have a manufacturer on it the pcb is marked RPCB488 v H
Edited by dave36
11 hours ago, james.wilson said:
a zoomed out one?
yes you will need to program 2 outputs. One as bell the other as strobe
No outputs default? I suppose op probably changed them anyway
11 hours ago, dave36 said:
IMG_0311.JPG.c0cb74f3a69cc9869a01f6d93eef75d0.JPGso here is the pic of the bell box, but I think its knowing where to put the wires in the galaxy 48 that the issue. Also I presume I have to program the galaxy outputs ?
So this is a deltabell?
On 03/12/2018 at 14:04, dave36 said:
Hi
Blue tamper , can't see what white is doing though
Have you got a picture on the 48 side I have feeling your connected to wrong connections
