Pyronix Enforcer bellbox, comfort strobe?
Gav1978
Are you looking for the strobe to give you conformation of setting /unset coopers panels can give you a 3 strobe flash on both so might be in setting progg
www.AllanMoncrieffAlarms.com
19 hours ago, Gav1978 said:
Hello, I'm sure it is possible but am struggling to find out how to do it.
I would like the bellbox to display a form of flashing LED when armed.  I would be grateful for any support or guidance with this.
Thank you
Or your basically using a wireless bellbox and it has no flashing LEDs in general
Only option is to put in a wired bell
The Pyronix wireless bell box has the option to enable/disable ‘comfort’ flashing LED’s.
46 minutes ago, Amps said:
Dunno.
Ah ok, was going to compare with hkc, they have additional battery pack gives you 24-36 months approx depending on flash rate , otherwise single normal pack will give you 6months
