optima G4 set up
Jack2000
small prob with Optima compact gen 4 - LED only.
all set up and all working OK - but although exit timer fine (as default), on entrance alarms immediately when door open - and can't seem to make the set up work to give an entry time.
went 'timed zones' , 'entry time'  setting procedure and no change, then set back to factory default (which should give 30 secs) - no change
So front door zone attribute should be entry or whatever manual calls it, timers obviously can't be zero
And then if you had a hall our like James said , attribute should be entry route or something like that so that when door is opened it doesn't trigger full alarm
thanks folks - entry door has its own zone (2) every other works fine, the door opening causes immediate alarm.
tried "entry time" set to 30 secs (03) and that didn't work, so maybe its the program thing.
set timed zone says -
Press [PROG] to give a choice of programs. LED’s 1, 2 and 3 are flashing.
• Select program [1, 2 or 3]. If program 1 is selected, LED 1 is ON.  -------- and I assume prog 1 (default anyway) is the one
• Press [2] to enter into Timed Zones. The first zone can now be
set as timed or untimed.
• To edit the other zones press [Number] to go to a particular zone.    -------- 2 toggled on for timed
but as Sixwheeled say - should that zone be inhibited? - cos being thick I am confused at this point
Quote
Timed Zones
A zone programmed as Timed would be used to protect the main entry/exit door of the entry route.
Inhibit Zones
This is a zone which, on setting the panel, allows access to the entry/exit zone. However, if the panel is set and a time inhibited zone is triggered before an entry/exit timed zone then an alarm will be generated immediately.
