xpertalarms Posted March 18, 2018 Share Posted March 18, 2018 About to takeover a site with a 3-144. Just been into RSS to start setting up the account and can't seem to find a option for 3-144. Never noticed this before! Would a GD264 panel type work? Remember coming across similar before and selecting another panel type was the only work around. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 18, 2018 Share Posted March 18, 2018 Galaxy gold starts doesn't it? Quote Link to comment Share on other sites More sharing options...
xpertalarms Posted March 18, 2018 Author Share Posted March 18, 2018 Yes, but isn't as nice! Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 18, 2018 Share Posted March 18, 2018 Yes, only Dimension, Flex and G2 panels have the newer interface. The 3-X panels use the same galaxy gold program as the old classic panels. The dimension is different hardware with a bigger flash chip, so there's no upgrade path for the old hardware other than switching the PCB out. Quote Link to comment Share on other sites More sharing options...
Amps Posted March 19, 2018 Share Posted March 19, 2018 19 hours ago, GalaxyGuy said: Yes, only Dimension, Flex and G2 panels have the newer interface. The 3-X panels use the same galaxy gold program as the old classic panels. The dimension is different hardware with a bigger flash chip, so there's no upgrade path for the old hardware other than switching the PCB out. I always get confused which is G3 and which is Dimension. How can you tell? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 19, 2018 Share Posted March 19, 2018 13 minutes ago, Amps said: I always get confused which is G3 and which is Dimension. How can you tell? I used to think the easiest way to determine the Dimension was by the vertical trigger header, but some of the later G3 were built with this PCB just to confuse things. It's best to identify by firmware version Dimension: V6.XX or V7.XX G3: V5.XX Quote Link to comment Share on other sites More sharing options...
xpertalarms Posted March 19, 2018 Author Share Posted March 19, 2018 (edited) Thanks GalaxyGuy. I usually tell the difference between the label on the panel lid, 3 series will have 3-xxx on the lid and dimension usually has 'galaxy 48', 'galaxy 96' on it etc etc Edited March 19, 2018 by xpertalarms Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 19, 2018 Share Posted March 19, 2018 Many installers will swap the board only, leaving the original PSU and case, as it's too much hassle changing the chassis. I suppose if you're lucky they will have changed the lid over to the new one, but selling what looks like a new dimension on eBay fetches more than an old g3 . Firmware version is guaranteed to give the correct type. Quote Link to comment Share on other sites More sharing options...
Amps Posted March 20, 2018 Share Posted March 20, 2018 12 hours ago, GalaxyGuy said: I used to think the easiest way to determine the Dimension was by the vertical trigger header, but some of the later G3 were built with this PCB just to confuse things. It's best to identify by firmware version Dimension: V6.XX or V7.XX G3: V5.XX Ok that’s a great help mate. So basically G3 was replaced with Dimension? May differences between the two? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted March 20, 2018 Share Posted March 20, 2018 5 hours ago, Amps said: Ok that’s a great help mate. So basically G3 was replaced with Dimension? May differences between the two? Yes, the Dimension replaced the G3-X when the G3-X was discontinued Sept 2008. Physically, just extra trigger outputs and a bigger flash chip to hold the Dimension firmware going forward. The Dimension firmware was updated to enable RF portal connection with panel based RF configuration (unlike the old RF RIO), but adding this option lowers the installation grading to 2. The Dimension, along with Flex panels also support the touch screen Touchcenter keypads now available in a better flush-mount housing (TouchCenter+ version). The Dimension and Flex panels also integrate access control. The Dimension range is available in 48, 96, 264, 520 zones and the old G3 was 48,144,520 zones. There are a few other small differences. One key thing to note with Honeywell is that the EOL products are unlikely to receive any firmware updates/fixes. 1 Quote Link to comment Share on other sites More sharing options...
Amps Posted March 20, 2018 Share Posted March 20, 2018 Cleared that up nicely Quote Link to comment Share on other sites More sharing options...
